+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 4
    Points: 1,449, Level: 8
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    Initializing an input port and then change its value
    There is an up/down counter entity where the direction is first set to '1' to count up. Another entity can change the direction if a condition is met. So the test bench looks like
    signal c: std_logic := '0'; -- clock
    signal r: std_logic := '0'; -- reset
    signal d: std_logic := '1'; -- direction
    signal cou: integer range 0 to 7; -- count value
    u0: counter port map( c, r, d, cou ); -- in, in, in, out
    u1: reader port map( a, cou, c, d, z ); -- in, in, in, out, out
    As you can see the 'd' is initialized to '1'. So, I expect that the counter counts up. However, in the simulation the value of 'd' is U. Well it is correct that assignment is not good because the input 'd' port of the counter receives two wire (one from the initialization and the other from reader).
    The architecture of counter is
    architecture behav of counter is
    	signal cnt: integer range 0 to 7:= 0;
    begin
    	process( rst, clk )
    	begin
    		if (rst = '1') then
    			cnt <= 0;
    		elsif (clk'event and clk = '1') then
    			if dir = '1' then
    				cnt <= cnt + 1;
    			else
    				cnt <= cnt - 1;
    			end if;
    		end if;
    	end process;
    	z <= cnt;
    end;
    Any idea?
    •   Alt6th July 2017, 15:18
      advertising
  2. #2
    Points: 5,380, Level: 17
    Join Date
    Apr 2016
    Posts
    1,131
    Points
    5,380
    Level
    17
    Re: Initializing an input port and then change its value
    why is d an output of the 'reader'? it is conflicting.
    if this up/down logic has to be part of the implemented hardware, using a constant to initialise it is a bad idea. make it a flop, add a reset.
    Really, I am not Sam.
  3. #3
    Member level 4
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    Well as I said, upon a condition in reader entity, the direction will be set to down (0).
    •   Alt6th July 2017, 15:45
      advertising
  4. #4
    Advanced Member level 5
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    If the signal "d" is connected to the ouput of a component, it will not matter what you initialised it to - it will take whatever the reader is driving, which appears to be 'U'.
    the initial value is just that - initial. The assignment from the component takes place in the 1st delta of simulation (0ns + 1delta).
  5. #5
    Join Date
    Apr 2016
    Posts
    1,131
    Points
    5,380
    Level
    17
    Quote Originally Posted by mahmood.n View Post
    that's fine. but then it makes no sense to initialise it, ever. that's not RTL.
  6. #6
    Member level 4
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    So, I added a reset input in the reader which set the direction to 1 (up count). That direction output port is connected to the direction input port of the counter. So reader sends either 1 or 0 (down count upon a condition) to the counter.
    The reset signal in the test bench is initially 1 and the goes to 0 in the architecture of the testbench. Do you agree with that?
    •   Alt6th July 2017, 17:06
      advertising
  7. #7
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    that would be pretty standard, if you have active high reset.
