Dear all,
I'm new on this forum and I'm glad to join your community.
I face a problem when I try to simulate a systemC program with ModelSim. Here the message error:
# vsim work.sc_main
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: (vopt-7) Failed to open debug database file "/work/_sc//moduleinfo.sc.link" in read mode.
# ** Error: (vopt-3675) Could not find shared library "/work/_sc//systemc.so for SystemC module 'sc_main'.
# ** Warning: (vopt-7) Failed to open SystemC shared library file "/work/_sc//systemc.so" in read mode.
# No such file or directory. (errno = ENOENT)
# ** Error: Failed to find design unit work.sc_main.
# Optimization failed
# Error loading design
Here the macro .do I use to compile and launch simulation:
# Create library
vlib work
#Compile systemC source
sccom -64 test.cpp
# Link
sccom -64 -link
#Load design
vsim -novopt sc_main
# Launch simulation
run -all
And here my simple source code:
#include "systemc.h"
SC_MODULE(MyModule)
  sc_signal<sc_logic> mySignal;
  void myThread();
  SC_CTOR(MyModule)
    SC_THREAD(myThread);
void MyModule::myThread()
  mySignal.write(SC_LOGIC_0);
  wait(100, SC_NS);
  mySignal.write(SC_LOGIC_1);
int sc_main(int argc, char* argv[])
  // * Elaboration *
  MyModule *my_module = new MyModule("myModule");
  // * Simulation *
  sc_start();
  // * Post-processing *
  delete my_module;
  return 0;
I have no problem loading and simulate VHDL design. Could it be a license issue ?
