[SOLVED] interfacing SR04 ultrasonic sensor with 16f877 UART not working
asthra123
Member level 1
hello everybody
please help me because i cant find out the problem in my asm code which is not working with uart tx(txpoll) subroutine . but without "UART TX(TXPOLL) subroutine the code is working fine.
  • Ultrasonic Sensor with PIC16F877 Assembly Source Code1.txt
--> Then do it this way.
Klaus
hello,
check bank .. for SPBRG & TXSTA using
    bcf        INTCON,GIE
        bsf            STATUS,RP0
    bsf        PIE1,TMR1IE
        banksel         T1CON
        bsf           T1CON,TMR1ON
initsci
       banksel  SPBRG     ;  <-------------------------  bank 1 !
       movlw  19h
       movwf  SPBRG
       movlw  25h         ;set up for async operation
       movwf  TXSTA
       bcf    STATUS,RP0  ;back to file 0 for a moment
       movlw  90h         ;enable serial port operations and the associated pins
       movwf  RCSTA
       clrf   TXREG       ;clear our serial port buffers for start up
       clrf   RCREG
       call   init
dear paulfjujo......
thank you very much its working......
thankyou for your valuable reply
