T
treez
Our software works on some of our PCBs but not others.
We program them with pickit3 and use ICSP.
Can we just plug the Pickit3 into the board and debug it like that?
When i try to debug I am getting "Connection failed" error in MPLAB X IDE. Do you know why?
I have the 5 pin header in the pickit3 and its connected to the PCB.
I actually programmed the board with this connector/wire assembly so i know the 5 lines are connected (MCLR,Vdd,Vss, PgD,PgC).
In order to do debugging, do i have to program the PIC18F26K20 with the ".hlx" file instead of the normal ".hex" file?
