flote21
Advanced Member level 1
Hello folks!! I have a question....imagine you want to estimate the minimum power to supply a PCB board with several digital components. These components are divided in two groups. 5Volt components and 3.3Vol components. The theoretical power consumptions for both voltages according to those components are: 5V/2A and 3.3V/1A. If the PCB is supply with 24V. Which is the minimum current from the 24V source you will need to reach the total power requirements?
Is there any good simulator to estimate the general power consumption of a PCB board according to the individual power consumption of every PCB board device?
Greetings!
Greetings!
