Results 1 to 3 of 3
    Newbie level 2
    Points: 18, Level: 1
    Jun 2017
    18
    nwell resisor inside n guard ring
    I have a resistor act as an injector that connect directly to external, if I put this nwell resistor inside n-type latch up guard ring, will that be a problem? like parasitic NPN?
    •   Alt19th June 2017, 17:31
      advertising
    Points: 32,428, Level: 43
    Mar 2008
    USA
    5,169
    32,428
    43
    Re: nwell resisor inside n guard ring
    It depends on whether you forward bias any junctions.
    Are you planning to take any terminals below substrate
    potential?
    •   Alt20th June 2017, 04:42
      advertising
    Newbie level 2
    Jun 2017
    18
    I have NMOS inside the lutch up guard ring, its like source to internal commmon mode voltage regulate and not connect to external
