Results 1 to 2 of 2
    Full Member level 3
    Points: 1,005, Level: 7
    Aug 2016
    185
    1,005
    7
    Trying to simulate a current supply using Pspice
    It's weird.
    1) Only 46.44nA running through a branch. That's too small to be a current supply
    2) I had to insert a resistor R14 100ohm else the simulation won't converged.
    3)Why point B dropped to 68.15mV? Transistor M4 sustain a huge VDS voltage across, almost 3.2V, that's not safe, right?
    How can i increase the current so it can a meaningful current supply?
    •   Alt19th June 2017, 03:23
      advertising
    Points: 25,716, Level: 39
    Nov 2001
    Earth
    3,628
    25,716
    39
    Re: Trying to simulate a current supply using Pspice
    Because the circuit does not start.You should add a starting transistor to wake up the circuit.
