convert the output of counter to an integer in simulink
hanikapa
Member level 4
I have the output of counter that is increasing in a stepwise. I nneed to have the maximum number to conver it to binary. Does any body have experience?
for example in the attached fig, the counting number at the output is 3 and I want to extract it.
hi,
how you want to extract it?
do you need to print it some where or just wanted to see in your software?
and can you please explain the above statement little more?
regards
The point is that this counter output is generated and on the otherhand there are some outputs from another counter that are generated . The output of both counters should be added. the output of one counter is 3 and the other counter is 4. But in the simulink, they are added in steps and not like this 3+4=7. I need to give me an absolute 7, so I can convert it to binary.
