CMOS Fully Differential Amplifier offset voltage
marsargo
Newbie level 1
Hello,
Im currently designing a fully differential two stages opamp and focusing on the offset reduction. I have run montecarlo simulations and got a suggestion that i should use differential current sources between the first stage output and gnd to reduce te offset voltage . How can i simulate a differential current source in cadence ?
If you mean adding a cancelling difference current, that
would want some sense of the proper difference. That
might mean an autozero phase, or periodic chopping and
sampling.
It ought to be easy to create a bidirectional current
mirror set that can be steered. The question that is
trickier is, who's at the wheel?
If your question is how to simply emulate a differential
current source pair, just use 2 idc elements with
different params such as i=imaster*kbalance and
i=imaster*(1-kbalance) where you vary kbalance
between 0 and 1 (0.5 being center) for unidirectional
differential current; for bidirectional, add an offset.
