+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 166, Level: 2
    Join Date
    Apr 2017
    Posts
    7
    Points
    166
    Level
    Synthesis: Check_Design Report too many warnings
    Hello everyone
    I have run DC. There were no error in my reports but there were a lot of warnings. I have attached some of the screenshots in my "check_design" report. Is this the reason why my formality test failed? If so, how can I reduced or eliminate the problem.
    •   Alt13th June 2017, 08:48
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,346, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,923
    Points
    20,346
    Level
    34
    Re: Synthesis: Check_Design Report too many warnings
    For one thing, it looks like you've got outputs connected to outputs. Not sure why that's only a warning and not an error. But I think you need to fix the problems that are causing the warnings if you don't want to see them...
  3. #3
    Super Moderator
    Points: 28,611, Level: 41
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,551
    Points
    28,611
    Level
    41
    barry I don't think the report is showing that outputs are shorted together.
    The report is saying you have an output port that is driven by a logic 1, i.e. the source of the output port is a logic 1.
    I also think there might be a connection problem on the alu_stat_wr[2] and alu_stat_wr[3] that needs to be looked at. Maybe the same statement is driving both ports.
    •   Alt13th June 2017, 18:56
      advertising
  4. #4
    Points: 5,800, Level: 18
    Join Date
    Apr 2016
    Posts
    1,221
    Points
    5,800
    Level
    18
    is this ASIC or FPGA? looks like you forgot to add tiehi/tielo cells to the design.
    Really, I am not Sam.
  5. #5
    Full Member level 4
    Points: 1,779, Level: 9
    Join Date
    May 2014
    Posts
    217
    Points
    1,779
    Level
    9
    Also your debug probe, is it 1 bit size connected to a std_logic_vector? you may need to configure the tool
    •   Alt4th July 2017, 16:32
      advertising
  6. #6
    Points: 35,892, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,567
    Points
    35,892
    Level
    46
    Quote Originally Posted by wesleytaylor View Post
    Im not sure where you see this - but this is not a problem. Often, 1 bit vectors come about when you have a component with a port sized by a generic (or it is generated code) and the size is set to 1.
    std_logic_vector(0 downto 0);
  7. #7
    Full Member level 4
    Join Date
    May 2014
    Posts
    217
    Points
    1,779
    Level
    9
    #6 I'm aware of that
    What it looked like was
    deb_0 <= sig1
    deb_0 <= sig2
    Because all the signals are on the same net.
    Whereas, what I'd expect would be.
    deb_0(0) <= sig1
    deb_0(1) <= sig2
    Anyway. I believe I misread the error messages earlier so the point is moot.
