+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 3
    Points: 473, Level: 4
    Join Date
    Feb 2017
    Posts
    65
    Points
    473
    Level
    How to work out with "inout" port in verilog?
    I want to write into the memory through a port and sometimes after I have it read the memory content through the same port. How to do this? I am unfamiliar about inout port
    •   Alt13th June 2017, 06:41
      advertising
  2. #2
    Points: 7,114, Level: 20
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,032
    Points
    7,114
    Level
    20
    Blog Entries
    Re: How to work out with "inout" port in verilog?
    This post will be helpful.
    https://electronics.stackexchange.co...ort-in-verilog
    Learn how to use a tri-state buffer.
    .....yes, I do this for fun!
  3. #3
    Member level 3
    Join Date
    Feb 2017
    Posts
    65
    Points
    473
    Level
    Why people talk about i2c instantiation or tristate logic when it comes to inout port of verilog.
  4. #4
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    I2C uses inout to implement the open drain buffers. In standard I2C, the bus lines are either driven 0 or z, never 1.
    In hardware terms, a tri-state buffer is the equivalent of an inout. Bidirectional data busses, e.g. memory data lines need to use tri-state buffers at all connected ports.
    •   Alt13th June 2017, 11:05
      advertising
  5. #5
    Member level 3
    Join Date
    Feb 2017
    Posts
    65
    Points
    473
    Level
    Module design 1(
    Input clka,clkb,
    Input we,re,
    Input [3:0] addra,addrb,
    Input [3:0] data,
    Output reg [3:0]
    Reg [3:0] ram [7:0];
    Reg [3:0] temp;
    always@(posedge clka)
    If(we)
    Ram[addra] <= data;
    always@(posedge clkb)
    If(re)
    Temp<= ram[addrb];
    Assign data = re ? Temp: 'dz;
    Endmodule
    This is both syntax free and synthesize able, but unable to write stimulus to "data" port. Tell me where it is wrong
  6. #6
    Advanced Member level 5
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    you need to declare "data" as inout, not input
  7. #7
    Member level 3
    Join Date
    Feb 2017
    Posts
    65
    Points
    473
    Level
    Re: How to work out with &quot;inout&quot; port in verilog?
    it is a typo mistake while typing in phone.
    Quote Originally Posted by FvM View Post
    how should i use tri-state buffers in the code i posted here.
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Your code already describes a 4-bit wide three-state buffer
    •   Alt13th June 2017, 18:34
      advertising
  9. #9
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Re: How to work out with &amp;quot;inout&amp;quot; port in verilog?
    Quote Originally Posted by hcu View Post
    I'll assume that the mixed case keywords is also an artifact of using the phone.
    [syntax=verilog]Input [3:0] data,
    //has to be a typo too, because this won't compile?
    Output reg [3:0]
    );[/syntax]
    This piece of code doesn't make a whole lot of sense:
    [syntax=verilog]always@(posedge clkb)
    If(re)
    Temp<= ram[addrb];
    Assign data = re ? Temp: 'dz;[/syntax]
    when a re pulses high for one clock cycle and is caught on the rising_edge of clock it will have gone away in the next cycle when the temp is assigned to data (in reality it will likely stick around for a few hundered ps due to Tco and routing delays). Only if re is high for two clock cycles with this work correctly, i.e. 1st clock reads the ram 2nd clock outputs the data. To properly enable the output you would have to use a delayed version of the re.
