+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 1
    Points: 1,293, Level: 8
    Join Date
    Jan 2011
    Posts
    15
    Points
    1,293
    Level
    8
    Route 455: CLK Net may have excessive skew
    While implementing designs such as counters I get warning such as Route 455: CLK Net may have excessive skew . I am not using any constraint file.
    Can that be reason? In that case can I ignore this??
    •   Alt12th June 2017, 15:58
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,994, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,853
    Points
    19,994
    Level
    34
    Re: Route 455: CLK Net may have excessive skew
    You may not be using a clock buffer, and that's causing the message. But why aren't you using a constraint? You may end up with a design that only runs at 60Hz.
