cipi-cips
Member level 4
Hello,
If someone could guide me how to calcute next problem,
I have a 50 loads that can be powerd from 6-12V and current consumption is 80mA connected in paralel with a distance between each other 10m. I have taken cabel resistance 20ohm per 100 meters.
Total cable lenght to connect all this loads is 500m which gives me 10kOhm over pozitive wire and 10kOhm resistance over negative wire. Total current that must go over circuit is 4Amps. I want to use car battery 12V 30ah.
Does this 12V 30Ah means that battery is ready to provide 30A over one hour but voltage wont drop ?
Will it be sufficent power supply 12V 4Ah ?
Do i must connect multiple battery packs ?
Goal is to secure sufficent voltage over network 12V for max voltage drop to 6V and supplying 80mA to all loads.
Regards
Regards
