+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 4
    Points: 1,668, Level: 9
    Join Date
    May 2014
    Posts
    197
    Points
    1,668
    Level
    9
    vhdl 2008 external/hierarchy names assignments and alias
    I've read the following thread.
    http://www.edaboard.com/thread295879.html
    I can successfully assign something like the following (in concurrent part of architecture)
    [syntax=vhdl]APB_IN.PRDATA <= << signal .SCP0466B1_tb.FPGA.PRDATA_S : std_logic_vector(31 downto 0)>>;[/syntax]
    however the following
    [syntax=vhdl]
    <<signal .SCP0466B1_tb.FPGA.PWDATA_S : std_logic >> <= APB_OUT.PWDATA
    [/syntax]
    just gives me a glitch see attached picture
    Click image for larger version.
    Also having problems with alias's
    [syntax=vhdl]
    -- signal RDATA : word32;
    alias PADDR_S is <<signal .SCP0466B1_tb.FPGA.PADDR_S : std_logic_vector(31 downto 0) >>;
    [/syntax]
    modelsim gives
    ** Error: (vsim-8523) Cannot reference the signal "/scp0466b1_tb/FPGA/PADDR_S" before it has been elaborated.
    from verror -all log
    vsim Message # 8523:
    A signal must have been elaborated before it can be referenced in an
    external name.
    The default value for the type of the signal has been used.
    [DOC: IEEE Std 1076-2008 VHDL LRM - 8.7 External names]
    [DOC: IEEE Std 1076-2008 VHDL LRM - 14.2 Elaboration of a design hierarchy]
    What am I doing wrong? Can't force concurrents apparently. Also does anyone have access to these sections of standard?
    •   Alt8th June 2017, 15:34
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Re: vhdl 2008 external/hierarchy names assignments and alias
    Without seeing the code, I can only guess that this is a multiple driver error? Are all of the signals X rather than U after the glitch? it could be a delta issue with the driver result changing between deltas (because the direct assignment would occur 1 delta before a clocked assignment, for example).
    I would recommend NOT driving anything internally from a testbench via hierarchial references. It can be a little confusing, and anything like this really should be driven via the interface (although it does seem normal to use heirarchical drivers in SV simulation components - much to others confusion!)
    The elaboration problem will be because you are trying to access a signal in an entity that hasnt been instantiated yet. I guess you're trying to declare it in the declarative region of the architecture?
    All you need to do it move the alias declaration below the entity "FPGA" in the code - either locally in a process, or if you need it in several processes, wrap them up in a generate region:
    FPGA : entity work.FPGA_ent port map ();
    multi_proc_gen : if true generate
    begin
      process ....
      process....
    end generate multi_proc_gen;
