+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 1
    Points: 1,064, Level: 7
    Join Date
    Oct 2014
    Posts
    114
    Points
    1,064
    Level
    7
    Building a programming cable for Xilinx CPLD / FPGA
    I am planning to build a cheap programming cable for Xilinx CPLDs/ FPGAs. I found one in the internet here. But I was confused with the cable wiring diagram. For FPGAs and CPLDs the programming pins are TDI, TDO, TMS and TCK. I could not find all the pins in the diagram. Are they renamed with other names here. Alternatively, does anyone know of any other simple DIY programmer.
    Thanks,
    Hobbyiclearner
    •   Alt6th June 2017, 08:37
      advertising
  2. #2
    Super Moderator
    Points: 241,537, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,939
    Points
    241,537
    Level
    100
    Re: Building a programming cable for Xilinx CPLD / FPGA
    You apparently overlooked the programmer schematic on this site. It does the 5 to 3.3V level translation and connects to JTAG interface.
    •   Alt6th June 2017, 11:39
      advertising
  3. #3
    Full Member level 1
    Join Date
    Oct 2014
    Posts
    114
    Points
    1,064
    Level
    7
    OK. In simple words I hope that the programmer will work for CPLD/ FPGA programming?
    Regards,
    Hobbyiclearner
    •   Alt7th June 2017, 07:15
      advertising
  4. #4
    Full Member level 1
    Join Date
    Oct 2014
    Posts
    114
    Points
    1,064
    Level
    7
    OK.. I found the ckt in an Xilinx application notes here. So I suppose it should work. I wanted to modify it to add a status LED to indicate if the programming cable works. Does anyone suppose that if I added a LED + resistor in parallel to 5 v supply, will the programmer continue working and indicate that it is getting power supply from FPGA/CPLD side (snapshot of modification attached.)Attachment 139405
    Pls. advise.
    Thanks,
    Hobbyiclearner
