How to include the sub-modules in top module ?
carrot
Full Member level 3
Bangalore, India
Can anyone tell how to include the sub-modules in top module in Nc-sim?
If i use in topmodule 'include submodule.v, while compiling it is giving "cannot open file "submodule.v"
Hi, carrot
Why not instance the sub-module in top module?
If you plan to use the "include", please tell the simulator the path of sub-module file.
Good Luck
just compile it .
if submodule are independent .
you must ncelab "top sub" to include the submodule in your database.
I have't used ncsim for a long time. However, I think you may do it as the follows:
1)
use 'include "sub-module.v" in your code, and put sub-module.v in the working
directory.
2)
in the command line, provide the path to sub-module.v
ncverilog -Iyour_directory_for_sub_modules top_module.v
I am not sure it will work. please try it!
Good luck.
