+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 1
    Points: 1,503, Level: 8
    Join Date
    Jun 2011
    Posts
    101
    Points
    1,503
    Level
    8
    synchronization or Asynchrony reading and writing SDRAM?
    module WR_RD_DSP16_clk(clk,
    DSP_ECLKOUT,
    DSP_ED,
    nWR,
    nRD,
    data
    input clk;//不同时钟域的clk
    input DSP_ECLKOUT;
    inout [15:0] DSP_ED;
    input nWR;
    input nRD;
    output [15:0] data;reg [15:0] data;
    reg [15:0] dsp_data;
    always @(posedge DSP_ECLKOUT)
     if(~nWR)
       dsp_data[15:0]<=DSP_ED[15:0];
     else
       dsp_data[15:0]<=dsp_data[15:0];
    assign DSP_ED[15:0]=(nRD) ? 16'hzzzz:dsp_data[15:0];
    always @(posedge clk)
    endmodule
    where nWR and nRD is:
    nWR =~(~DSP_CE& ~DSP_AWE& (DSP_EA[21:2]==20'h00000));
    nRD =~(~DSP_CE& ~DSP_ARE&~DSP_AOE&(DSP_EA[21:2]==20'h00000));
    Dear all:
    This is a code read and write SDRAM,but I don't know it is synchronization or asynchrony,I think SDRAM must be synchronization ,but it's seem be asynchrony from the code.
    And what the function of this sentence:
    Thank you very much!
    •   Alt6th June 2017, 03:13
      advertising
  2. #2
    Super Moderator
    Points: 27,994, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,395
    Points
    27,994
    Level
    40
    Re: synchronization or Asynchrony reading and writing SDRAM?
    This says it's syncrhonous
    the nWR and nRD are produced combinationally but are used synchronous to the clock.
    the assign is saying output High-Z on the output pins when reading data from the SDRAM. DSP_ED is an inout.
