Results 1 to 14 of 14
    Member level 4
    Points: 548, Level: 4
    Feb 2017
    77
    548
    Combinatorial loop and its effects ? how to avoid this ?
    my verilog code line at the end looks like this ,
    assign Total_result = x ? result1 : y ? result2 : Total_result ;
    This forms a combinatorial loop and linting tool shows error here and while vivado tool shows warning and tells timing may fail later.
    how can i rewrite this,
    if i use procedural assignment block like
    always@(posedge clk)
    This may remove error, but the result will consume 1 clock cycle more which i dont want.
    some help is really appreciated.
    Last edited by FvM; 5th June 2017 at 07:39. Reason: Explicitely referring to FPGA tools, moved to FPGA section
    Points: 57,592, Level: 58
    Apr 2014
    11,730
    57,592
    58
    Re: Combinatorial loop and its effects ? how to avoid this ?
    Neither in combinatorial, nor in clocked mode your formula will give useful results.
    What do you want to achieve with this?
    --> I assume you need an additional variable for the result.
    What initial value has Total_result? Maybe zero?
    Then the value will toggle with every clock cycle between 0 and infinite.
    •   Alt5th June 2017, 07:32
      advertising
    Points: 241,537, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,937
    241,537
    100
    It's legal Verilog code for a latch with input mux, I believe. You should know if a latch can work reliable in this place or if a clocked register is required. Prerequisite for correct latch operation is that all other inputs are stable when x or y are switching from transparent to latching state. Also x and y must have no glitches.
    Warnings should be expected in the former case, but which error do you see?
    Consider that asynchronous circuits are not well supported by FPGA timing synthesis tools.
    but the result will consume 1 clock cycle more which I don't want.
    In most cases, it's better to apply reasonable pipelining to a registered design than trying to fix a bad asynchronous construct.
    Full Member level 4
    Points: 1,779, Level: 9
    May 2014
    217
    1,779
    9
    Do you need to assign it to itself if those conditions are not met?
    •   Alt5th June 2017, 12:43
      advertising
    Points: 5,800, Level: 18
    Apr 2016
    1,221
    5,800
    18
    Quote Originally Posted by hcu View Post
    This is naive code construction, latches should be avoided 99 out of 100 times. Make the block sequential like it should be. Pay attention to the difference between blocking and non-blocking assignments (= versus <=)
    Really, I am not Sam.
    •   Alt5th June 2017, 13:34
      advertising
    Member level 4
    Feb 2017
    77
    548
    Quote Originally Posted by wesleytaylor View Post
    no need! i have no thoughts , just to fullfill the syntax, i did that.
    Quote Originally Posted by ThisIsNotSam View Post
    I say it is a typo mistake. but anyhow for a single statement. it doesnot matter whether it is = or <=.
    see ! i have actually two srams in my design from where i read the data from those two memories periodically. As per status of some flags (here x andy )i should do multiplexing of those two data_out ports of memories.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,937
    241,537
    100
    If you just want a mux, why did you implement a latch?
    Why not
    assign Total_result = cond ? result1 : result2;
  8. #8
    Apr 2016
    1,221
    5,800
    18
    It does matter. You will get simulation mismatches, lint errors, synthesis warnings, and most importantly will be mocked by your peers.
    I think you need a mux, like FvM said.
  9. #9
    Points: 28,611, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,551
    28,611
    41
    If all hcu needs is a mux then they are writing their code with the thought process of a software coder.
    @hcu Look at all your code as hardware, if you want to select between two RAM outputs, think I need a multiplexer not think of some code like you initially proposed, where you treat a "variable" as some storage where you can read the value out of it and store it back into the same variable.
    Storage in software is easy to manipulate that way, storage written in that fashion in hardware ends up making latches. I see this all the time with interns writing code. Makes me wonder what the schools are teaching engineering students now days.
  10. #10
    Member level 4
    Feb 2017
    77
    548
    Why not
    if my register x is high, i should select the data output of first ram.
    if my register y is high, i should select the data output of second ram.
    both x and y never gets high at the same time, forget about this.
    both x and y gets to low at the same time, where in this case, my port total_result shouldn't get data from either memories.
    how u do this?
    •   Alt5th June 2017, 17:16
      advertising
  11. #11
    ads-ee's Avatar
    Sep 2013
    USA
    6,551
    28,611
    41
    Use a combinational multiplexer...
    Code Verilog - [expand]
    always @* begin
      case ({x,y})
        2'b10 : total_result <= result1;
        2'b01 : total_result <= result2;
        default : total_result <= 0;  // or whatever constant you want
      endcase
    end
    I also don't see the point in distinguishing that the output can't be either RAM when {x,y} == 2'b00 it shouldn't matter what the output is, as you probably shouldn't be looking at the total_result value when you have that condition.
  12. #12
    Member level 4
    Feb 2017
    77
    548
    Quote Originally Posted by ads-ee View Post
    always @* begin
      case ({x,y})
      endcase
    end
    this removed combinatorial issue, but inferred latch . it is due to incomplete case statement.
  13. #13
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,937
    241,537
    100
    Unlikely. By adding the default case, it becomes complete. Guess your code is somehow different.
  14. #14
    Full Member level 4
    May 2014
    217
    1,779
    9
    To avoid timing, consider
    always@(posedge clk) begin
      Total_result_reg = Total_result;
    end
    //stuff
      Total_result = x ? result1 : y ? result2 : Total_result_reg ;
