T
treez
Hello,
We wish to attach the attached type of thermocouple to our mosfet cases so as to measure the temperature of the FET case. Please recommend a cost-effective glue for this?
We were also wondering about just using kapton tape to stick the thermocouple end to the fet case….and just squirting some thermal paste over the thermocouple end before the kapton tape is applied so as to give better thermal coupling of the thermocouple junction to the fet case.
What do you recommend for thermocouple attachement to FET cases? We realise a glued thermocouple end cannot be re-used, ..it has to be cut off and the PTFE shield has to be stripped back so that another thermocouple junction can be made, leaving the overall thermocouple wire length shorter.
