Alireza9168
Newbie level 1
I want to use a VCO (Ros 2650+ ((mini circuit IC))) for a FMCW Radar. Actually I want to set a sweep time for a voltage sawtooth ramp that is the input of vco to get FM signal in out.
My sweep time is 10us and voltage range is from 6 to 9 volt to get a 150 MHz. Ros 2650+ can work linearity in 500 MHz range and i use it to work linear but i don't know my sweep time is OK to settle 150 MHz in 10us or not.I heared the modulation bandwidth of vco determine it but I don't know how
(Ros 2650+ has 28 MHz modulation bandwidth). can anyone help me?
