srpronto
Newbie level 2
Hi guys,
I'm doing a project and I came to a problem, maybe two.
I'm using a RAM that stores 18 : std_logic_vectors(6 downto 0). I'm using two counters in this project, one changes the adress and the other changes the value on that adress. Both values of the counters are being shown on the HEX of the board.
The problema is:
- When i change a value, on some of the adresses, it appears to change right (even two the numbers looked bugged on the HEX) but and when i change to a higher adress the value i put on other adress seems to follow and make those next adresses with the same or other value that i didn't put at start.
In this project i need to be able to read the value that currently is stored on RAM and need to write to it at the same time. I'm not sure if the problem is on the RAM, i guess the problem is on the clocks i use (currently using 50MHz clock on the board), but i need some guidance . Any more code you need to look at just tell me.
The problema is:
Code:library ieee; use ieee.std_logic_1164.all; entity single_port_ram is port( Readclock : in std_logic; WriteClock : in std_logic; address : in natural range 0 to 17; writeData : in std_logic_vector(6 downto 0); reset : in std_logic; load : in std_logic; currentData : out std_logic_vector(6 downto 0); readData1 : out std_logic_vector(6 downto 0); readData2 : out std_logic_vector(6 downto 0); readData3 : out std_logic_vector(6 downto 0); readData4 : out std_logic_vector(6 downto 0); readData5 : out std_logic_vector(6 downto 0); readData6 : out std_logic_vector(6 downto 0); readData7 : out std_logic_vector(6 downto 0); readData8 : out std_logic_vector(6 downto 0); readData9 : out std_logic_vector(6 downto 0); readData10 : out std_logic_vector(6 downto 0); readData11 : out std_logic_vector(6 downto 0); readData12 : out std_logic_vector(6 downto 0); readData13 : out std_logic_vector(6 downto 0); readData14 : out std_logic_vector(6 downto 0); readData15 : out std_logic_vector(6 downto 0); readData16 : out std_logic_vector(6 downto 0); readData17 : out std_logic_vector(6 downto 0) ); end single_port_ram; architecture rtl of single_port_ram is subtype TWord is std_logic_vector(6 downto 0); type TMemory is array(17 downto 0) of TWord; signal s_memory : TMemory; signal addr_reg : natural range 0 to 17; begin process(WriteClock) begin if(rising_edge(clock)) then s_memory(address) <= writeData; if (reset = '1') then s_memory(1) <= (others => '0'); s_memory(2) <= (others => '0'); s_memory(3) <= (others => '0'); s_memory(4) <= (others => '0'); s_memory(5) <= (others => '0'); s_memory(6) <= (others => '0'); s_memory(7) <= (others => '0'); s_memory(8) <= (others => '0'); s_memory(9) <= (others => '0'); s_memory(10) <= (others => '0'); s_memory(11) <= (others => '0'); s_memory(12) <= (others => '0'); s_memory(13) <= (others => '0'); s_memory(14) <= (others => '0'); s_memory(15) <= (others => '0'); s_memory(16) <= (others => '0'); s_memory(17) <= (others => '0'); elsif (load = '1') then s_memory(1) <= "1000000"; s_memory(2) <= "1000000"; s_memory(3) <= "1000000"; s_memory(4) <= "1000000"; s_memory(5) <= "1000000"; s_memory(6) <= "1000000"; s_memory(7) <= "1000000"; s_memory(8) <= "1000000"; s_memory(9) <= "1000000"; s_memory(10) <= "1000000"; s_memory(11) <= "1000000"; s_memory(12) <= "1000000"; s_memory(13) <= "1000000"; s_memory(14) <= "1000000"; s_memory(15) <= "1000000"; s_memory(16) <= "1000000"; s_memory(17) <= "1000000"; end if; end if; addr_reg <= address; end process; process (ReadClock) begin if rising_edge(ReadClock) then readData1<= s_memory(1); readData2<= s_memory(2); readData3<= s_memory(3); readData4<= s_memory(4); readData5<= s_memory(5); readData6<= s_memory(6); readData7<= s_memory(7); readData8<= s_memory(8); readData9<= s_memory(9); readData10<= s_memory(10); readData11<= s_memory(11); readData12<= s_memory(12); readData13<= s_memory(13); readData14<= s_memory(14); readData15<= s_memory(15); readData16<= s_memory(16); readData17<= s_memory(17); end if; end process; currentData <= s_memory(addr_reg); end rtl;
