Sevdam
Newbie level 6
Hey guys,
I am trieng to simulate a horn-pyramidal antenna for the w-band (75 GHz-110 GHz). I calculated all parameters I need (A, B, ..)and now the simulation using HFSS. The Problem is that it takes a couple of hours till i get the result: simulation did not converged.
my settings for the setup:
max. number of passes: 10
max. delta S: 0.0002
max. refinement per pass: 10%
max. delta Z_0 = 0.2%
interpolation sweep:
min. Solution: 2
min. number of subranges : 4
min. Solution: 2
