manush30
Member level 1
Hi friends,
I driving LED with this TI's driver
https://www.ti.com/lit/ds/symlink/tps92512.pdf
I'm trying to write a code with PWM dimming control.
According to the datasheet the dimming range is 100Hz to 1kHz(Pg. 12)
In pg. 17 they give an example to a design with oscilloscope images(pg. 20) (PWM signals)
I try to write a code with the ability to choose duty cycle to work with.
(My board connect to outside CPU to select duty cycle thru I2C)
attached a little clock diagram.
I really need help here guys...:idea::???:
