rmmstn
Newbie level 6
Can you tell why an IC might get warmer even if you stay far away from your rated voltage? I asked something close to this for max414cpd before. Probably, the chip is not the issue because i tried giving 10v to two different identical ICs . Both gave me the same problem? In the datasheet it states that I can give 10v.
Thank you a lot.
Thank you a lot.
