Selection of SMPS with correct wattage
jerryvdk
Member level 1
Hi all,
I don't know whether this is the right category to post this question. I need to build a panel which is controlling stepper motors and has some controllers and sensors. It must be powered using an SMPS which will give you a 24V DC ouput. The confusion is how to select SMPS(Specification) for this kind of system.
If the stepper motor is rated for 4A and if we are using a chopper driver to drive it, i think motor wont need a constant 4A inorder to operate. So it there are 2 4A motors and one controller which is rated for1.5A at 24V. How to select smps with correct current output?.
Is it like 2*4 + 1.5 = 9.5A, 24V?
SMPS are problematic when overloaded. The voltage drops almost immidealtely.
Therefore you need to avoid overload.
If the motor draws 4A or less ... we can´t say. YOU have to decide.
Usually a stepper has a couple of windings, be sure to take care of the overall current. And take care about worst case cenarios.
I´d try to avoid voltage drops that may cause a system reset.
Klaus
Klaus
Motors can be thought of an LR circuit . If my motor winding resistance is 2.4ohms and inductance is 9.5mH, then time constant is L/R = 3.95. Circuit will take 5*3.95 = 19.7ms to reach its maximum current (24/2.4 = 10A). Since we are using a chopper drive, it will cut the circuit when it senses 4A.
In this case the power source(SMPS ) has to provide only 4A for a little amount of time(< ms).
So do we need to select 4A SMPS to power this motor in this scenario?
if you can be sure that your application doesn´t draw more current (we don´t know) ....
Klaus
