NovelPanda
Junior Member level 3
Resonance found between probe (finite inductance) and circuit
Dear All:
I have designed a 30GHz PLL which I plan to use probe for testing. There are approximated 100pF equivalent cap between VDD and VSS inside the chip after C+CC extraction. The probe is estimated to have about 20pH inductance (with Q>20??) each and I have 4-Pad for VDD supply. When I insert a Vsin in series with the ideal power supply I measure the "VDD" after the probe inductance, and found that there is always a resonance around 1GHz with 2dB peak. It seems that adding more Decap on-chip does not help attenuate the resonance anymore. I will be very appreciated if someone can share experience on this suggesting what should I do in the last few days before tapeout and during measurement. In fact, this may explain why we can get a better phase noise result before when we did wirebonding and measurement on PCB with LDO, compared to on chip probing.
Thanks in advance!
Dear All:
Thanks in advance!
