T
treez
Suppose we have a 150W LED lamp, and the FR4 LED driver PCB is all surface mount.
Now suppose the LEDs and the driver PCB are both placed on the same heatsink.
This would be advantageous for the DPAK Power FETs, because they will have a heatsink beneath them that they can be thermal via’d to.
-But what about the small SMD resistors and capacitors?
Surely, with them being mounted on the PCB on the hot heatsink (that gets used for LEDs too), they will heat up more than they otherwise would and stand a greater chance of cracking due to thermal cycling?
