Results 1 to 14 of 14
    Junior Member level 1
    Points: 120, Level: 1
    Mar 2017
    India
    18
    120
    Dimmer AC Circuit Resistor burns
    Hi,I'm doing a dimmer which is connected to a relay to work as a switch to Turn ON/OFF.
    Now the circuit which I implemented is this
    where I'm using MOC3021 & BT138-800E(TRIAC)
    and according to the MOC3021 Datasheet its written as for a sensitive gate use this Fig.2
    Now my real doubt is where to connect Load ? whether to MT2 or MT1?
    because both the figures shows different connections
    and I think there will be no much difference if we change the terminals
    and when I start dimming then the resistor connected to MT2 is getting burnt whether its 1k,10k,10k1/2W anything
    and for 2-3 times the dimming worked after that the resistor starts burning?
    is it because any other device like MOC3021 got burnt within this 2-3times or any other reasons?
    please help me through this
    Thanks in Advance
    Points: 22,705, Level: 36
    andre_teprom's Avatar
    Nov 2006
    Portugal
    6,912
    22,705
    36
    Blog Entries
    Re: Dimmer AC Circuit Resistor burns
    if we change the terminals and when I start dimming then the resistor connected to MT2 is getting burnt whether its 1k,10k,10k1/2W anything
    Are you using any strongly reactive load, such as a motor ?
    If yes, it is missing a snubber on your circuit.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Mar 2017
    India
    18
    120
    Quote Originally Posted by andre_teprom View Post
    The load is Incandescent bulb, and I've a snubber circuit too.
    This is the circuit which I'm working on where relay is also a part of the circuit :)
    •   Alt20th May 2017, 06:29
      advertising
    Points: 228,909, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,481
    228,909
    100
    Resistors > 2k will probably been overloaded and shouldn't been used. If 1k resistor burns, you have either a problem with non-triggering triac (defective or different type than BT138 with high trigger threshold) or a shorted capacitor. The capacitor must be rated for 250 VAC or at least 630 VDC.
    Points: 43,011, Level: 50
    Most Frequent Poster
    Apr 2014
    8,801
    43,011
    50
    We don't see how you drive the MOC's LED.
    According datasheet the max current to trigger the MOC is 15mA. I doubt there are 15mA.
    But I don't know what happens when LED current is too low.
    To be at the safe side: follow the datasheet recommendations.
    •   Alt22nd May 2017, 06:50
      advertising
    Mar 2017
    India
    18
    120
    Thanks @FvM
    can you please elaborate this ?
    Thanks @Klaus
    MOCs LED is driven from the controller using program
    int AC_LOAD = 3; // Output to Opto Triac pin
    int dimming = 128; // Dimming level (0-128) 0 = ON, 128 = OFF
    void setup()
    Serial.begin(9600);
    pinMode(AC_LOAD, OUTPUT); // Set the AC Load as output
    attachInterrupt(digitalPinToInterrupt(2), zero_crosss_int, RISING); // Choose the zero cross interrupt
    void zero_crosss_int() // function to be fired at the zero crossing to dim the light
    // Firing angle calculation :: 50Hz-> 10ms (1/2 Cycle)
    // (10000us - 10us) / 128 = 75 (Approx)
    int dimtime = (75*dimming);
    delayMicroseconds(dimtime); // Off cycle
    digitalWrite(AC_LOAD, HIGH); // triac firing
    delayMicroseconds(10); // triac On propogation delay
    digitalWrite(AC_LOAD, LOW); // triac Off
    void loop()
    dimming = 90;
    delay(7000);
    dimming = 50;
    delay(7000);
    dimming = 20;
    delay(7000);
    •   Alt22nd May 2017, 07:13
      advertising
  7. #7
    Apr 2014
    8,801
    43,011
    50
    I am referring to currents (and/or voltages)
  8. #8
    Mar 2017
    India
    18
    120
    Voltage @ MOC 1,2 pin is 12.7mV
  9. #9
    Apr 2014
    8,801
    43,011
    50
    this is a useless value.
    If you compare the 12.7mV with the values given in the datasheet you may see it canīt work.
    I donīt like guessing, but with your given informations we need to.
    So I assume you measured the voltage with a DVM .. and the control signal is PWMīd.
    We canīt know if your DVM reading is the average value or the RMS value. We canīt know the drive voltage, we canīt know duty cycle. --> Impossible to verify your circuit.
    •   Alt23rd May 2017, 08:36
      advertising
  10. #10
    Mar 2017
    India
    18
    120
    Sorry, even I'm unable to understand because now its showing as 0.53V but mostly its showing 0.0V (its always been varying)
    but dimming is happening
    so what may be the issue ?
  11. #11
    Apr 2014
    8,801
    43,011
    50
    --> use a scope.
    In cas eyou donīt have one, then buy one or lend one.
  12. #12
    Mar 2017
    India
    18
    120
    any idea why it is not showing any voltage @ MOC?
    and what are the cases where MOC & BT138 could be damaged?
    hey @FvM, the cap 0.1uF should be 275VAC one?
  13. #13
    Mar 2017
    India
    18
    120
    --> use a scope.
    is 0.53V is also wrong voltage @ MOC?
  14. #14
    Mar 2017
    India
    18
    120
    Hi,now my dimming is working without any fault or damage of resistors when I replaced 0.1uF cap by 0.1uF/275VAC
    But I'm still getting 0.4V @MOC3021 and 1.09V @4N35
    And guys help me with the circuit I've attached where relay is also connected,the problem is when I send some instruction even without the relay being ON the dimming is happening instead it should only dim when relay is ON and according to the instruction given the dim should change
    Thanks in advance
