Data transfer between GPRS modem and Remote server
rnarayanan15
Newbie level 2
I was develop one project based on send and receive data from remote server for that i were using quectel m66 modem and send by HTTP. But it take time up to 12 seconds how to reduce the time. My data is only 800 bits and my modem operates at 2G. If anybody know how to reduce that delay?
The total traffic is probably much more than "800 bits". To decide if the problem is in the m66 firmware or your way to use it, you'll best tap the TCP communication on the server side.
Are you accessing the modem through HTTP AT commands?
Thank you for your response sir, I am already try TCP connection but its also take 10 seconds delay and also TCP need always server in open otherwise unable to send data. Yes i am access by using HTTP commands from modem datasheet. There is two way to use http one is GET and another one is POST method. I am using GET method.
