Shematic to PCB help.
Englewood
Full Member level 3
I have designed a small circuit using Proteus and the simulation works fine.
I built the circuit on breadboard and worked great, was chuffed.
I've decided I want to make a better PCB and not use breadboard, ive used design spark to layout my PCB and had a few made but there is always something wrong, I'm not sure if its my PCB layout or manufacturing errors. Its only a very small circuit consisting of 3 relays, 2 switches, a Laser and a motor.
5V Power
5V Single Pole Realy
2 x 5V DPDT Relay
3-5V Motor
3-5 Laser.
I have had 3 designs of PCB made and I have errors still, got half of the circuit working but the other half failed, I know what components I need to use.
Would any of you experts be able to create the PCB for me if I can send you the Shematic drawing?.
Or is there any free online software I can use to design my Shematic, simulate, transfer to PCB then order the PCB?
I have use OSH PARKS for my PCB's .
Hope you can help, would be very grateful.
You should be able to figure out what's wrong with your pcb. Maybe a footprint is wrong.this is almost trivial.
