Hspice not able to output tr0 files properly ? can't see the waveform
reddvoid
Junior Member level 3
I have a hspice code I am trying to simulate
Code PHP - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
*** PARAMETER INITIALIZATIONS ***
.PARAM LOAD_GTDOUT = 1e-9
.PARAM LOAD_ATOUT = 10f
.PARAM LOAD_BTOUT = 10f
.PARAM TSTEP = 1E-012
.PARAM PFREQ = 100M
.PARAM PPERIOD = '1/PFREQ'
.PARAM SLOPE_TIN =8.3n
.PARAM PWIDTH = '(0.5*PPERIOD)-SLOPE_TIN'
.PARAM TDELAYA = 1n
.PARAM TDELAYB = 20n
*.PARAM TSTOP = 'TDELAY+1*PPERIOD'
.PARAM TSTOP = 200n
.PARAM HSUP = 1.1
.PARAM LSUP = 0.0
.TEMP 80
***** Extraction netlist ******
.inc '/home/j/inputs/ckt.dspf'
**** Model files () *******
.inc "/opt/models/include_nom"
*** ACCURACY OPTIONS ***
.OPTION TRITOL   = .1
.OPTION DELSTART = 1E-12
.OPTION DELMIN   = 0.1e-17
.OPTION RESCAT   = 100E-12
.OPTION RELTOL   = 1E-4
.OPTION ABSTOL   = 1E-15
.OPTION INITOP   = PREVOP
.OPTION METHOD   = GEAR MXORD=3
.OPTION GMIN     = 1E-15
.OPTION CHGTOL   = 1E-15
.OPTION POST
.OPTION INGOLD   = 2
.OPTION MEASFORM = 2
.OPTION NUMDGT = 6
*.OPTION LIS_NEW = 1
.OPTION PROBE = 1
.OPTION ITRPRT = 1
*.OPTION acct brief nomod csdf probe
.ic v(GTDOUT) = 0
*** SUPPLY SPECIFICATION ***
Vvdd VCC 0 HSUP
Vvss VSS 0 LSUP
***** DUT SPECIFICATION *****
XI1 TINA ATOUT TINB BTOUT GTDOUT VCC VSS ckt
*.OPTION NONOMIN
*** TRANSIENT ANALYSIS ***
.TRAN TSTEP TSTOP
*** LOAD SPECIFICATION ***
CLOAD_ATOUT ATOUT VSS LOAD_ATOUT
CLOAD_BTOUT BTOUT VSS LOAD_BTOUT
CLOAD_GTDOUT GTDOUT1 VSS LOAD_GTDOUT
*** PULSE STATEMENT ***
V_TinA TINA VSS PULSE(HSUP LSUP TDELAYA SLOPE_TIN SLOPE_TIN PWIDTH PPERIOD)
V_TinB TINB VSS PULSE(HSUP LSUP TDELAYB SLOPE_TIN SLOPE_TIN PWIDTH PPERIOD)
V_GTDOUT GTDOUT GTDOUT1 LSUP
*** MEASUREMENT STATEMENT ***
.MEASURE TRAN PAVG_ALL_M AVG LX34(X*.M*) from=0 to=200n
.PRINT V(TINA)
.PRINT V(TINB)
.PRINT V(ATOUT)
.PRINT V(BTOUT)
.PRINT V(GTDOUT)
.PROBE V(GTDOUT)
.END
but when I try to open the .tr0 file in cscope it comes out to be just blank
and also tr0 file size is 245340Bytes
Is this due to something that is/missing in accuracy options ?
Thanks
Try to use the following in your code: .OPTION POST=1 and use .PROBE(*) for testing purpose only.
Also, try to open your .st0 file with waveviewer (wv at terminal) .
Regards.
Regards.
Thanks for reply
I tried .OPTION POST = 1 and .PROBE(*)
but its still the same
and I don't have waveviewer
Code PHP - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
*st0 file contents*
****** HSPICE -- L-2016.06-2 linux64 (Jul 26 2016) ******
 Input File: d04clgpws11wqub0.hsp
 lic:
 lic: FLEXlm: v11.2.1
 lic: USER:   rbm                  HOSTNAME: bgsxlc151
 lic: HOSTID: "e4115b9603e4"       PID:      29806
 lic: Using FLEXlm license file:
 lic: /p/inway_local/license/lmadmin/snps/snps_pdx01_lic
 lic: Checkout 1 hspice
 lic: License/Maintenance for hspice will expire on 30-jan-2018/2017.03
 lic: 317(in_use)/6900(total) FLOATING license(s) on SERVER /p/inway_local/license/lmadmin/snps/snps
 lic:
 init: begin read circuit files,  cpu clock=  1.27E+00
       option search = /nfs/imu/proj/inway/eda/synopsys/hspice/L-2016.0
                         6-2/hspice/parts/ad
       option runlvl
       option cmipath = /p/inway/tech-prerelease/pub/tech/p1273/.dr/epic
                         /v1.0.105/cmi
       option pdmi_lib = /p/inway/tech-prerelease/pub/tech/p1273/.dr/epic
                         /v1.0.105/cmi/pdmi_64.so
       option cmiflag =     1.00
       option process_dev_params =     1.00
       option pdmi = 1
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option nomod =     1.00
       option xmult_in_expr = yes
       option tritol =    0.100
       option delstart =    1.000E-12
       option delmin =    1.000E-18
       option rescat =    1.000E-10
       option reltol =    1.000E-04
       option abstol =    1.000E-15
       option initop = prevop
       option method = gear
       option mxord =     3.00
       option gmin =    1.000E-15
       option chgtol =    1.000E-15
       option post =     1.00
       option ingold =     2.00
       option measform =     2.00
       option numdgt =     6.00
       option probe =     1.00
       option itrprt =     1.00
 init: end read circuit files,  cpu clock=  1.43E+00 peak memory=       236 mb
 init: begin check errors,  cpu clock=  1.43E+00
 init: end check errors,  cpu clock=  1.47E+00 peak memory=       237 mb
 init: begin setup matrix, pivot=     0 cpu clock=  1.47E+00
       establish matrix -- done,  cpu clock=  1.47E+00 peak memory=       237 mb
       re-order matrix -- done,  cpu clock=  1.48E+00 peak memory=       237 mb
 init: end setup matrix,  cpu clock=  1.49E+00 peak memory=       237 mb
 dcop: begin dcop,  cpu clock=  1.50E+00
       establish matrix -- done,  cpu clock=  1.84E+00 peak memory=       237 mb
       re-order matrix -- done,  cpu clock=  1.87E+00 peak memory=       238 mb
 dcop: end dcop,  cpu clock=  1.88E+00 peak memory=       238 mb  tot_iter=     225
 output: d04clgpws11wqub0.mt0
 sweep: tran tran0    begin, stop_t=  2.00E-07 #sweeps=**** cpu clock=  1.88E+00
 tran: time= 2.4150E-08 tot_iter=     144 conv_iter=      58 cpu clock= 2.06E+00
 tran: time= 4.1978E-08 tot_iter=     266 conv_iter=     105 cpu clock= 2.23E+00
 tran: time= 6.1978E-08 tot_iter=     270 conv_iter=     107 cpu clock= 2.24E+00
 tran: time= 8.1978E-08 tot_iter=     274 conv_iter=     109 cpu clock= 2.24E+00
 tran: time= 1.0198E-07 tot_iter=     278 conv_iter=     111 cpu clock= 2.25E+00
 tran: time= 1.2198E-07 tot_iter=     282 conv_iter=     113 cpu clock= 2.26E+00
 tran: time= 1.4198E-07 tot_iter=     286 conv_iter=     115 cpu clock= 2.26E+00
 tran: time= 1.6198E-07 tot_iter=     290 conv_iter=     117 cpu clock= 2.27E+00
 tran: time= 1.8198E-07 tot_iter=     294 conv_iter=     119 cpu clock= 2.28E+00
 tran: time= 2.0000E-07 tot_iter=     298 conv_iter=     121 cpu clock= 2.28E+00
 sweep: tran tran0    end,  cpu clock=  2.29E+00 peak memory=       238 mb
I think you have to tell HSPICE the output format which your viewer (cscope ?) can understand.
