Page 1 of 2 1 2 LastLast
Results 1 to 20 of 27
    Full Member level 4
    Points: 1,223, Level: 7
    Feb 2016
    209
    1,223
    7
    Cordic Algorithm Question
    I am implementing CORDIC algorithm.
    The source code could be found at https://www.edaplayground.com/x/3tHk or below:
    I have some problem with the look up table 'arctan' in the code. My fraction representation could be incorrect for the calculation of z[i+1].
    Could anyone help ?
    [syntax=verilog]module cordic(z0, xn, yn);
    input [6:0] z0;
    output [6:0] xn, yn;
    parameter N= 40; // number of iterations
    reg [(N-1):0] d;
    reg [(N-1):0] x, y, z, arctan [(N-1):0];
    initial begin
    arctan[0] = 1;
    for(integer j=0; j<(N-1); j=j+1)
    begin
    arctan[j+1] = arctan[j] >> (j+1);
    end
    end
    always @(*)
    begin
    for(integer i=0; i<N; i=i+1)
    begin
    d[i] = (z[i]<0) ? -1 : 1;
    x[i+1] = x[i] - y[i]*d[i] >> i;
    y[i+1] = y[i] + x[i]*d[i] >> i;
    z[i+1] = z[i] - d[i]*arctan[i];
    end
    end
    assign x[0] = 0.6073;
    assign y[0] = 0;
    assign z[0] = z0;
    assign xn = x[N-1]; // xn = cos(z0)
    assign yn = y[N-1]; // yn = sin(z0)
    endmodule[/syntax]
    [syntax=verilog]`timescale 1ns/100ps
    module cordic_tb;
    reg [6:0] z0, xn, yn;
    cordic C1
    .z0(z0), .xn(xn), .yn(yn)
    initial begin
    $dumpfile("cordic.vcd");
    $dumpvars(0, cordic_tb);
    z0 = 30;
    #20 $finish;
    end
    endmodule[/syntax]
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    Re: Cordic Algorithm Question
    I have modified the code accordingly after cross-checking with the octave code. However, why y[2] == 0 ?
    i= 0, x[i]=10011011011101001, y[i]=00000000000000000, z[i]=0000000000000000011110, d[i]= 0, arctan[i]=0000000000000000101101
    i= 1, x[i]=10011011011101001, y[i]=10011011011101001, z[i]=1111111111111111110001, d[i]= 1, arctan[i]=0000000000000000011011
    i= 2, x[i]=00011011011101001, y[i]=00000000000000000, z[i]=0000000000000000001100, d[i]= 0, arctan[i]=0000000000000000001110
    i= 3, x[i]=00000110110111010, y[i]=00000110110111010, z[i]=1111111111111111111110, d[i]= 1, arctan[i]=0000000000000000000111
    i= 4, x[i]=00000001101101110, y[i]=00000000000000000, z[i]=0000000000000000000101, d[i]= 0, arctan[i]=0000000000000000000100
    i= 5, x[i]=00000000000110110, y[i]=00000000000110110, z[i]=0000000000000000000001, d[i]= 0, arctan[i]=0000000000000000000010
    i= 6, x[i]=00000000000000000, y[i]=00000000000000011, z[i]=1111111111111111111111, d[i]= 1, arctan[i]=0000000000000000000001
    i= 7, x[i]=00000000000000000, y[i]=00000000000000000, z[i]=0000000000000000000000, d[i]= 0, arctan[i]=0000000000000000000000
    i= 8, x[i]=00000000000000000, y[i]=00000000000000000, z[i]=0000000000000000000000, d[i]= 0, arctan[i]=0000000000000000000000
    i= 9, x[i]=00000000000000000, y[i]=00000000000000000, z[i]=0000000000000000000000, d[i]= 0, arctan[i]=0000000000000000000000
    Done
    function [ Co,Si] = Cordic( De0 )
    De0=input('De0=')
    Co0=0.60725;
    Si0=0;
    Cos_ar=[];
    Sin_ar=[];
    De_ar=[];
    Cos_ar(1)=Co0;
    Sin_ar(1)=Si0;
    De_ar(1)=De0;
    i=1;
    while(1)
    tj=2.^-(i-1);
    phi=atand(tj);
    if(De_ar(i)>=0)
        D=1;
    else
        D=-1;
    end
        De_ar(i+1)=De_ar(i)-D*phi;
        Cos_ar(i+1)=Cos_ar(i)-D*tj.*Sin_ar(i);
        Sin_ar(i+1)=Sin_ar(i)+D*tj.*Cos_ar(i);
        Co=Cos_ar(i);
        Si=Sin_ar(i);
        A=cosd(De0);
        B=sind(De0);
        if(abs(B-Si)<0.0001 && abs(A-Co)<0.0001)
            break
        end
        i=i+1;
    end
    Cosde=cosd(De0)
    Sinde=sind(De0)
    Co
    Si
    i
    end
    input [21:0] z0;
    output [16:0] xn, yn;
    parameter N= 10; // number of iterations
    reg [(N-1):0] d;
    reg [16:0] x [(N-1):0];
    reg [16:0] y [(N-1):0];
    reg [21:0] z [(N-1):0];
    reg [21:0] arctan [(N-1):0];
    initial begin
    x[0] = 'b10011011011101001; // 0.60725 in binary
    y[0] = 0;
    arctan[0] = 45.0;
    arctan[1] = 26.6;
    arctan[2] = 14.0;
    arctan[3] = 7.1;
    arctan[4] = 3.6;
    arctan[5] = 1.8;
    arctan[6] = 0.9;
    arctan[7] = 0.4;
    arctan[8] = 0.2;
    arctan[9] = 0.1;
    end
    integer i;
    always @(*)
    begin z[0] = z0;
    for(i=0; i<N; i=i+1)
    begin
    d[i] = (z[i][16] == 0) ? 0 : 1;
    if(d[i] == 0) begin
    x[i+1] = x[i] - y[i] >> i;
    y[i+1] = y[i] + x[i] >> i;
    z[i+1] = z[i] - arctan[i];
    end
    else begin
    x[i+1] = x[i] + y[i] >> i;
    y[i+1] = y[i] - x[i] >> i;
    z[i+1] = z[i] + arctan[i];
    end
    $display("i=%2d, x[i]=%b, y[i]=%b, z[i]=%b, d[i]=%2d, arctan[i]=%b", i,x[i],y[i],z[i],d[i],arctan[i]);
    end
    end
    endmodule[/syntax]
    module cordic_tb;
    reg[21:0] z0;
    wire[16:0] xn, yn;
    cordic C1
    initial begin
    #10 z0 = 30;
    end
    endmodule[/syntax]
    Points: 239,577, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,510
    239,577
    100
    You apparently realized that
    makes no sense.
    But you are still assigning real values to unsigned arctan[] array, keeping only the integer part, as the variable dump shows. Need to think about a suitable fractional number representation.
    •   Alt13th May 2017, 17:00
      advertising
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    Thanks FvM.
    However, my focus now is not on fractional representation of that arctan array since they are being approximated by simulator. I will however take extra care of the arctan array when I am done with the logic flow of the algorithm.
    By the way, do you have any idea why y[2] == 0 ?
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    I have solved the bugs. Lines 40, 41, 46 and 47 have to be written in the following manner:
    x[i+1] = x[i] - (y[i] >>> i);
    Now, when I move on to pipelined version of the same logic, I face problem with d and z. https://www.edaplayground.com/x/4ymA
    I have a feeling that the pipeline structure that I am using is not right. Could anyone advise ?
    [syntax=verilog]module cordic_pipelined(clk, z0, xn, yn);
    input clk;
    input [21:0] z0;
    reg d;
    reg [16:0] x, x_next;
    reg [16:0] y, y_next;
    reg [21:0] z, z_next;
    integer i, i_next;
    initial begin
    x = 'b10011011011101001; // 0.60725 in binary
    y = 0;
    i = 0;
    i_next = 0;
    arctan[0] = 45.0;
    arctan[1] = 26.6;
    arctan[2] = 14.0;
    arctan[3] = 7.1;
    arctan[4] = 3.6;
    arctan[5] = 1.8;
    arctan[6] = 0.9;
    arctan[7] = 0.4;
    arctan[8] = 0.2;
    arctan[9] = 0.1;
    end
    always @ (posedge clk)
    begin
    x <= x_next;
    y <= y_next;
    z <= z_next;
    i <= i_next;
    end
    always @(*)
    begin z = z0;
    d = (z[21] == 0) ? 0 : 1;
    if(d == 0) begin
    x_next = x - (y >>> i);
    y_next = y + (x >>> i);
    z_next = z - arctan[i];
    end
    else begin
    x_next = x + (y >>> i);
    y_next = y - (x >>> i);
    z_next = z + arctan[i];
    end
    if (i<(N-1))
    i_next = i + 1;
    $display("i=%2d, x=%b, y=%b, z=%b, z_next=%b, d=%2d, arctan[i]=%b", i,x,y,z,z_next,d,arctan[i]);
    end
    assign xn = x; // xn = cos(z0)
    assign yn = y; // yn = sin(z0)
    endmodule[/syntax]
    module cordic_pipelined_tb;
    reg clk;
    reg[21:0] z0;
    wire[16:0] xn, yn;
    cordic_pipelined C1
    .clk(clk), .z0(z0), .xn(xn), .yn(yn)
    initial begin
    $dumpfile("cordic_pipelined.vcd");
    $dumpvars(0, cordic_pipelined_tb);
    clk = 0;
    z0 = 45;
    #120 $finish;
    end
    always #5 clk = !clk;
    endmodule[/syntax]
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    You can't put real numbers into a reg:
        y = 0;
        i = 0;
        i_next = 0;
        arctan[0] = 45.0;
        arctan[1] = 26.6;
        arctan[2] = 14.0;
        arctan[3] =  7.1;
        arctan[4] =  3.6;
        arctan[5] =  1.8;
        arctan[6] =  0.9;
        arctan[7] =  0.4;
        arctan[8] =  0.2;
        arctan[9] =  0.1;
    this will result in the following arctan[0] thru arctan[9] values:
        arctan[0] = 22'd45;
        arctan[1] = 22'd26;
        arctan[2] = 22'd14;
        arctan[3] =  22'd7;
        arctan[4] =  22'd3;
        arctan[5] =  22'd1;
        arctan[6] =  22'd0;
        arctan[7] =  22'd0;
        arctan[8] =  22'd0;
        arctan[9] =  22'd0;
    x is 17 bits and the arctan values should be 17-bit fractional values if you want your decimal points to like up so, arctan should have values like so:
    arctan[4] = 22'h073333;
    arctan[8] = 22'h006666;
    arctan[9] = 22'h003333;
    and currently your edaplayground code shows:
        arctan[0] = 'b101101_0000; // 45.0;
        arctan[1] = 'b011010_1001; // 26.6;
        arctan[2] = 'b001110_0000; // 14.0;
        arctan[3] = 'b000111_0001; // 7.1;
        arctan[4] = 'b000011_1001; // 3.6;
        arctan[5] = 'b000001_1100; // 1.8;
        arctan[6] = 'b000000_1110; // 0.9;
        arctan[7] = 'b000000_0110; // 0.4;
        arctan[8] = 'b000000_0011; // 0.2;
        arctan[9] = 'b000000_0001; // 0.1;
    which is wrong, .1 cannot be represented in binary as 'b00000_0001
  7. #7
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    ads-ee,
    Why 0.1 cannot be represented in binary as 'b00000_0001 ?
    I have updated the pure combinatorial circuit code version at https://www.edaplayground.com/x/449A or below:
    Although it works for me, I suspect there are still some bugs around z0, z and arctan. Could you advise ?
    input [10:0] z0;
    reg [(N-1):0] d;
    reg [10:0] z [(N-1):0];
    reg [10:0] arctan [(N-1):0];
    initial begin
    x[0] = 'b010011011011101001; // 0.60725 in binary
    y[0] = 0;
    arctan[0] = 'b010_1101_0000; // 45.0;
    arctan[1] = 'b001_1010_1001; // 26.6;
    arctan[2] = 'b000_1110_0000; // 14.0;
    arctan[3] = 'b000_0111_0001; // 7.1;
    arctan[4] = 'b000_0011_1001; // 3.6;
    arctan[5] = 'b000_0001_1100; // 1.8;
    arctan[6] = 'b000_0000_1110; // 0.9;
    arctan[7] = 'b000_0000_0110; // 0.4;
    arctan[8] = 'b000_0000_0011; // 0.2;
    arctan[9] = 'b000_0000_0001; // 0.1;
    end
    integer i;
    always @(*)
    begin z[0] = z0;
    begin
    d[i] = (z[i][10] == 0) ? 0 : 1;
    if(d[i] == 0) begin
    x[i+1] = x[i] - ((y[i]) >> i);
    y[i+1] = y[i] + ((x[i]) >> i);
    end
    else begin
    x[i+1] = x[i] + ((y[i]) >> i);
    y[i+1] = y[i] - ((x[i]) >> i);
    end
    end
    end
    endmodule[/syntax]
    module cordic_tb;
    reg [10:0] z0;
    wire [16:0] xn, yn;
    cordic C1
    initial begin
    #10 z0 = 10'b010_1101_0000;
    end
    endmodule[/syntax]
  8. #8
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    Quote Originally Posted by promach View Post
    ads-ee,
    If you think that can be done then why do you have x = 'b10011011011101001; // 0.60725 in binary
    There isn't any consistency between the two representations.
    Maybe you should learn how fractions are represented in binary, or do you plan on making your own math library for your special numeric representation. You'll have to have all the functions +, -, x, /, etc all as instantiated components to do such a thing as the synthesis tools use the representation I gave for binary fractions.
  9. #9
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    ads-ee:
    Thanks. I understand how fraction is represented now.
    I have implemented three versions of the cordic algorithm:
    Combinatorial: https://www.edaplayground.com/x/449A
    Clocked: https://www.edaplayground.com/x/4MQN
    Pipelined: https://www.edaplayground.com/x/4ymA
    I am trying to fix some unknown states (z[i]=xxxxxxxxxxx) on three code versions before synthesis. Once successful synthesis and hardware testing, I will upload directly source code of all three versions in this thread.
    Why would RHS of https://www.diffchecker.com/9YTcSxXK generate unknown state (z[i]=xxxxxxxxxxx) while LHS would not ?
Name:	Screenshot from 2017-05-17 00-33-24.png
    •   Alt16th May 2017, 17:35
      advertising
  10. #10
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    Because the right side code will only perform the z[0]=z0 once initially and your testbench only sets z0 at #10 so it's always X prior to that. Besides that since the assignment is inside the initial block z[0] isn't even logically connected to the z0 input. The left sets z[0] on every rising edge of the clock, so it eventually gets set to the constant at #10 in the testbench. If you want z[0] to be CONNECTED to z0 then you can use assign z[0] = z0; or do the assignment inside a always @* block to keep z[0] as a reg type.
    Using initial blocks to set constants (and assigning inputs to internal logic) in Verilog is wrong. You should make all the constants parameter or localparm and get rid of the initial block. IMO initial blocks do not belong in synthesizable code and if you have them you can't port the code to an ASIC and expect it to work as ASIC tools ignore synthesis of initial blocks.
    I don't think you really understand Verilog very well. You should read the LRM or a Verilog book not an online tutorial. Nearly all the online tutorials are terrible or inaccurate.
    •   Alt16th May 2017, 18:55
      advertising
  11. #11
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    Thanks. I am reading on parameter now since I have the following problem.
    I have "error: syntax error in parameter list." for the following line #15:
    parameter [10:0] arctan [9:0] =
    11'b000_0000_0001, 11'b000_0000_0011, 11'b000_0000_0110, 11'b000_0000_1110, 11'b000_0001_1100,
    11'b000_0011_1001, 11'b000_0111_0001, 11'b000_1110_0000, 11'b001_1010_1001, 11'b010_1101_0000
    vcs does not detect such syntax error, but iverilog does ? Why ?
    input [10:0] z0;
    reg [(N-1):0] d;
    reg [16:0] x [N:0];
    reg [16:0] y [N:0];
    reg [10:0] z [N:0];
    assign x[0] = 'b0_10011_0110_1110_1001; // 0.60725 in binary
    assign y[0] = 0;
    assign z[0] = z0;
    integer i;
    always @(*)
    begin
    begin
    if(d[i] == 0) begin
    x[i+1] = x[i] - (y[i] >> i);
    y[i+1] = y[i] + (x[i] >> i);
    end
    else begin
    x[i+1] = x[i] + (y[i] >> i);
    y[i+1] = y[i] - (x[i] >> i);
    end
    end
    end
    assign xn = x[N]; // xn = cos(z0)
    assign yn = y[N]; // yn = sin(z0)
    endmodule[/syntax]
  12. #12
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    I have solved the above problem.
    It was found that pure verilog does not allow parameter array, while systemverilog allows.
    I am planning to design the cordic algorithm in multi-cycle implementation.
    Is it possible ?
    If yes, how many states would it have ?
  13. #13
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    ads-ee:
    Could I consider the following as multi-cycle design ?
    [syntax=verilog]module cordic_clocked(clk, rst, z0, xn, yn);
    input clk, rst;
    input [10:0] z0;
    reg [(N-1):0] d;
    reg [16:0] x [N:0];
    reg [16:0] y [N:0];
    reg [10:0] z [N:0];
    wire [10:0] arctan [(N-1):0];
    assign arctan[0] = 'b010_1101_0000; // 45.0;
    assign arctan[1] = 'b001_1010_1001; // 26.6;
    assign arctan[2] = 'b000_1110_0000; // 14.0;
    assign arctan[3] = 'b000_0111_0001; // 7.1;
    assign arctan[4] = 'b000_0011_1001; // 3.6;
    assign arctan[5] = 'b000_0001_1100; // 1.8;
    assign arctan[6] = 'b000_0000_1110; // 0.9;
    assign arctan[7] = 'b000_0000_0110; // 0.4;
    assign arctan[8] = 'b000_0000_0011; // 0.2;
    assign arctan[9] = 'b000_0000_0001; // 0.1;
    reg [3:0] i;
    always @(posedge clk)
    begin
    if(rst) begin
    x[0] <= 'b0_10011_0110_1110_1001; // 0.60725 in binary
    y[0] <= 0;
    z[0] <= z0;
    i <= 0;
    end
    else begin
    if(d[i] == 0) begin
    x[i+1] <= x[i] - (y[i] >> i);
    y[i+1] <= y[i] + (x[i] >> i);
    z[i+1] <= z[i] - arctan[i];
    end
    else begin
    x[i+1] <= x[i] + (y[i] >> i);
    y[i+1] <= y[i] - (x[i] >> i);
    z[i+1] <= z[i] + arctan[i];
    end
    i <= i + 1;
    end
    $display("rst=%1b, i=%2d, x[i]=%b, y[i]=%b, z[i]=%b, d[i]=%2d, arctan[i]=%b",rst, i,x[i],y[i],z[i],d[i],arctan[i]);
    end
    endmodule[/syntax]
    module cordic_clocked_tb;
    reg clk, rst;
    reg [10:0] z0;
    wire [16:0] xn, yn;
    cordic_clocked C1
    .clk(clk), .rst(rst), .z0(z0), .xn(xn), .yn(yn)
    initial begin
    $dumpfile("cordic_clocked.vcd");
    $dumpvars(0, cordic_clocked_tb);
    rst = 1;
    clk = 0;
    z0 = 11'b010_1101_0000;
    #10 rst = 0;
    #100 $finish;
    end
    endmodule[/syntax]
  14. #14
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    I'm not sure you understand that a multicycle design isn't just a design that is pipelined. It is a design that allows multiple clock cycles before an operation completes. The outputs of the first set or registers holds unchanged over two or more clocks cycles and the next register caputures the result at the end of those clock cycles. This is usually done by including an enable in the design.
  15. #15
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    ads-ee: Regarding the multi-cycle design, let me do it again.
    I have two long questions which I will split into two posts.
    A) https://www.edaplayground.com/x/449A
    I am trying to capture xn=x[i] into a text file named "cos_out.txt". Same applies to yn and zn.
    There should be 10 entries in the text file.
    However, I am only getting only a single xn in the text file, which is the value of x[9] in the last iteration.
    Any advice ?
    module cordic(z0, xn, yn, zn);
    input [10:0] z0;
    output reg [16:0] xn, yn;
    output reg [10:0] zn;
    reg [(N-1):0] d;
    integer i;
    always @(*)
    begin
    y[0] = 0;
    z[0] = z0;
    begin
    if(d[i] == 0) begin
    end
    else begin
    end
    xn = x[i]; // xn = cos(z0)
    yn = y[i]; // yn = sin(z0)
    zn = z[i];
    end
    end
    endmodule[/syntax]
    module cordic_tb;
    reg [10:0] z0;
    wire [16:0] xn, yn;
    wire [10:0] zn;
    // file operators
    integer I_out, Q_out, Z_out;
    cordic C1
    .z0(z0), .xn(xn), .yn(yn), .zn(zn)
    initial begin
    I_out = $fopen("cos_out.txt", "w"); // Output file for debugging
    Q_out = $fopen("sin_out.txt", "w"); // Output file for debugging
    Z_out = $fopen("angle_out.txt", "w"); // Output file for debugging
    z0 = 11'b010_1101_0000; // 45 degrees
    #100
    $fclose(I_out);
    $fclose(Q_out);
    $fclose(Z_out);
    #10 $finish;
    end
    always @(xn, yn, zn)
    begin
    $fwrite(I_out, "%d\n", xn);
    $fwrite(Q_out, "%d\n", yn);
    $fwrite(Z_out, "%d\n", zn);
    end
    endmodule[/syntax]
    B) https://www.edaplayground.com/x/4ymA
    I have some problem debugging unknown states (xxxxxxxxx) in between pipeline stages.
    I understand it takes time to fill in the pipeline slots for x_o, y_o and z_o, but it should only be one clock cycle, right ? The verbose simulation output does not align with the observation of continuous xxxxxxxx states across stages. Any help ?
    [2017-05-18 03:06:02 EDT] iverilog '-Wall' 'cordic_stage.v' design.sv testbench.sv && unbuffer vvp a.out
    VCD info: dumpfile cordic_pipelined.vcd opened for output.
    i= 0, x_i=10011011011101001, y_i=00000000000000000, z_i=01011010000, x_next=10011011011101001, y_next=10011011011101001, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=01011010000
    i= 1, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00110101001
    i= 2, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00011100000
    i= 3, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00001110001
    i= 4, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000111001
    i= 5, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000011100
    i= 6, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000001110
    i= 7, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000110
    i= 8, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000011
    i= 9, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000001
    i= 0, x_i=10011011011101001, y_i=00000000000000000, z_i=01011010000, x_next=10011011011101001, y_next=10011011011101001, z_next=00000000000, x_o=10011011011101001, y_o=10011011011101001, z_o=00000000000, d= 0, arctan[i]=01011010000
    i= 1, x_i=10011011011101001, y_i=10011011011101001, z_i=00000000000, x_next=01001101101110101, y_next=11101001001011101, z_next=11001010111, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=00110101001
    i= 1, x_i=10011011011101001, y_i=10011011011101001, z_i=00000000000, x_next=01001101101110101, y_next=11101001001011101, z_next=11001010111, x_o=01001101101110101, y_o=11101001001011101, z_o=11001010111, d= 0, arctan[i]=00110101001
    i= 2, x_i=01001101101110101, y_i=11101001001011101, z_i=11001010111, x_next=10001000000001100, y_next=11010101110000000, z_next=11100110111, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00011100000
    i= 2, x_i=01001101101110101, y_i=11101001001011101, z_i=11001010111, x_next=10001000000001100, y_next=11010101110000000, z_next=11100110111, x_o=10001000000001100, y_o=11010101110000000, z_o=11100110111, d= 1, arctan[i]=00011100000
    i= 3, x_i=10001000000001100, y_i=11010101110000000, z_i=11100110111, x_next=10100010101111100, y_next=11000100101111111, z_next=11110101000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00001110001
    i= 3, x_i=10001000000001100, y_i=11010101110000000, z_i=11100110111, x_next=10100010101111100, y_next=11000100101111111, z_next=11110101000, x_o=10100010101111100, y_o=11000100101111111, z_o=11110101000, d= 1, arctan[i]=00001110001
    i= 4, x_i=10100010101111100, y_i=11000100101111111, z_i=11110101000, x_next=10101111000010011, y_next=10111010100101000, z_next=11111100001, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00000111001
    i= 4, x_i=10100010101111100, y_i=11000100101111111, z_i=11110101000, x_next=10101111000010011, y_next=10111010100101000, z_next=11111100001, x_o=10101111000010011, y_o=10111010100101000, z_o=11111100001, d= 1, arctan[i]=00000111001
    i= 5, x_i=10101111000010011, y_i=10111010100101000, z_i=11111100001, x_next=10110100110111100, y_next=10110101000111000, z_next=11111111101, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00000011100
    i= 5, x_i=10101111000010011, y_i=10111010100101000, z_i=11111100001, x_next=10110100110111100, y_next=10110101000111000, z_next=11111111101, x_o=10110100110111100, y_o=10110101000111000, z_o=11111111101, d= 1, arctan[i]=00000011100
    i= 6, x_i=10110100110111100, y_i=10110101000111000, z_i=11111111101, x_next=10110111101100100, y_next=10110010010010010, z_next=00000001011, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00000001110
    i= 6, x_i=10110100110111100, y_i=10110101000111000, z_i=11111111101, x_next=10110111101100100, y_next=10110010010010010, z_next=00000001011, x_o=10110111101100100, y_o=10110010010010010, z_o=00000001011, d= 1, arctan[i]=00000001110
    i= 7, x_i=10110111101100100, y_i=10110010010010010, z_i=00000001011, x_next=10110110010011011, y_next=10110011101110000, z_next=00000000101, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=00000000110
    i= 7, x_i=10110111101100100, y_i=10110010010010010, z_i=00000001011, x_next=10110110010011011, y_next=10110011101110000, z_next=00000000101, x_o=10110110010011011, y_o=10110011101110000, z_o=00000000101, d= 0, arctan[i]=00000000110
    i= 8, x_i=10110110010011011, y_i=10110011101110000, z_i=00000000101, x_next=10110101100110100, y_next=10110100011011100, z_next=00000000010, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=00000000011
    i= 8, x_i=10110110010011011, y_i=10110011101110000, z_i=00000000101, x_next=10110101100110100, y_next=10110100011011100, z_next=00000000010, x_o=10110101100110100, y_o=10110100011011100, z_o=00000000010, d= 0, arctan[i]=00000000011
    i= 9, x_i=10110101100110100, y_i=10110100011011100, z_i=00000000010, x_next=10110101010000000, y_next=10110100110010001, z_next=00000000001, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=00000000001
    i= 9, x_i=10110101100110100, y_i=10110100011011100, z_i=00000000010, x_next=10110101010000000, y_next=10110100110010001, z_next=00000000001, x_o=10110101010000000, y_o=10110100110010001, z_o=00000000001, d= 0, arctan[i]=00000000001
    Finding VCD file...
    ./cordic_pipelined.vcd
    [2017-05-18 03:06:03 EDT] Opening EPWave...
    Done
    input clk;
    input [10:0] z0;
    parameter N = 10; // number of iterations
    reg [(N-1):0] d;
    wire [16:0] x [N:0];
    wire [16:0] y [N:0];
    wire [10:0] z [N:0];
    assign y[0] = 0;
    assign z[0] = z0;
    genvar i;
    generate
    begin
    cordic_stage #(.i(i)) stage_i
    .clk(clk),
    .x_i(x[i]), .x_o(x[i+1]),
    .y_i(y[i]), .y_o(y[i+1]),
    .z_i(z[i]), .z_o(z[i+1]),
    .arctan(arctan[i])
    end
    endgenerate
    endmodule[/syntax]
    module cordic_stage(clk, x_i, y_i, z_i, x_o, y_o, z_o, arctan);
    input [10:0] arctan;
    parameter i=0;
    input clk;
    input [16:0] x_i, y_i;
    input [10:0] z_i;
    output [16:0] x_o, y_o;
    output [10:0] z_o;
    reg d;
    reg [16:0] x_o, x_next;
    reg [16:0] y_o, y_next;
    reg [10:0] z_o, z_next;
    begin
    x_o <= x_next;
    y_o <= y_next;
    z_o <= z_next;
    end
    always @(*)
    begin
    d = (z_i[10] == 0) ? 0 : 1;
    if(d == 0) begin
    x_next = x_i - (y_i >> i);
    y_next = y_i + (x_i >> i);
    z_next = z_i - arctan;
    end
    else begin
    x_next = x_i + (y_i >> i);
    y_next = y_i - (x_i >> i);
    z_next = z_i + arctan;
    end
    $display("i=%2d, x_i=%b, y_i=%b, z_i=%b, x_next=%b, y_next=%b, z_next=%b, x_o=%b, y_o=%b, z_o=%b, d=%2d, arctan[i]=%b", i,x_i,y_i,z_i,x_next,y_next,z_next,x_o,y_o,z_o,d,a rctan);
    end
    endmodule[/syntax]
    reg clk;
    reg [10:0] z0;
    wire [16:0] xn, yn;
    cordic_pipelined C1
    initial begin
    clk = 0;
    #120 $finish;
    end
    endmodule[/syntax]
  16. #16
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    A) because for loops are not used for writing sequential operations, which is what you are trying to use if for. Every time a read signal changes in the always @(*) block the for loop iterates over all 0-9 i values instantly in 0 time. What you've described is a large deep combinational "blob" of logic. So yeah, all you will get is the last [9] iteration output.
    The other for loop in the generate replicates 10 copies of your cordic_stage logic.
    B) I also don't get why there is an issue with the x's you have 10 stages of cordic_statge logic each one has a register in it that is initially X, so you get a display of a bunch of signals with X 10 times, one for each of the cordic_stage instances (as they all have a display task in them). I kind of suspect you don't know what your code translates to in hardware. Personally I would have made the display task in the testbench and accessed all the nodes in the design using the '.' hierarchy, that would have avoided the confusing mess of the output. I'd also change to use hex output to make the output shorter and easier to read.
    If the values were correctly done as binary fixed point then you could have used %.8f (e.g. 8-bit fractional) to output fixed point decimal values, but as you've got some non-standard custom method of representing fractional data you can't do this, too bad for you.
  17. #17
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    ads-ee:
    A) If I wish to capture all 10 entries into the text file instead of the last [9] iteration output, could you advise how to do it since the for loop iterates in zero time ?
    B) Thanks for the "." hierarchy advice, however it does not work in accessing generated instances of cordic_stage.
    Do you have any idea how to implement the .start() as shown in http://stackoverflow.com/a/7341055/6422632
    Besides, what do you mean by "If the values were correctly done as binary fixed point then you could have used %.8f (e.g. 8-bit fractional) to output fixed point decimal values," ?
Name:	Screenshot from 2017-05-19 17-16-36.png
  18. #18
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    ads-ee:
    $display (....., C1.x[0], C1.x[1], ...etc);
    Though you'll need to name the begin-end block (i.e. begin : name_of_block) of the for loop so you can add that name into the . hierachy, which answers your B problem below.
    Not sure what their problem was, but here is a post about accessing signals in a generate block module instantiation, I use this all the time in my code. http://www.edaboard.com/showthread.p...=1#post1065894
    Try this in a simulator:
    A 2's complement 12-bit with 12-bit fractional (Q11.12 or fx12.24).
    [syntax=verilog] reg [23:0] fixed_point_binary = 24'h015_001; // 21.000244140625 exactly
    initial begin
    $display ("%.12f", fixed_point_binary/4096.0);
    end
    [/syntax]
    My apologies, I see now that you were using values rounded to 1 decimal place:
    [syntax=verilog]module display_test;
    initial begin
    end
    integer i;
    // requires compiling with -sv option enabled
    reg [9:0] arctan [0:9] = '{10'h2d_0, 10'h1a_9, 10'h0e_0, 10'h07_1, 10'h03_9,
    10'h01_c, 10'h00_e, 10'h00_6, 10'h00_3, 10'h00_1};
    initial begin
    $display ("Acutal fractional values");
    for (i=0;i<10;i=i+1) begin
    $display ("%.4f", arctan[i]/16.0);
    end
    $display ("Rounded to 1 decimal place");
    $display ("%.1f", arctan[i]/16.0);
    end
    end
    endmodule[/syntax]
    # 21.000244140625
    # Actual fractional values
    # 45.0000
    # 26.5625
    # 14.0000
    # 7.0625
    # 3.5625
    # 1.7500
    # 0.8750
    # 0.3750
    # 0.1875
    # 0.0625
    # Rounded to 1 decimal place
    # 45.0
    # 26.6
    # 14.0
    # 7.1
    # 3.6
    # 1.8
    # 0.9
    # 0.4
    # 0.2
    # 0.1
    Didn't realize this because there is nothing in your comments that indicate the values as being rounded and the code included a comment that had the exact precision value for: 'b0_10011_0110_1110_1001; // 0.60725 in binary. You should avoid doing such rounding (for a comment) or at leas specify that the values are rounded to one decimal place.
    So sorry about continually harping about your lack of using standard binary fractional representation.
  19. #19
    Full Member level 4
    Feb 2016
    209
    1,223
    7
    ads-ee:
    I have modified using your method accordingly as follows, but it gives me unpredicted verbose output especially i ?
    [2017-05-21 21:06:34 EDT] iverilog '-Wall' 'cordic_stage.v' design.sv testbench.sv  && unbuffer vvp a.out
    design.sv:54: warning: @* is sensitive to all 11 words in array 'x'.
    design.sv:55: warning: @* is sensitive to all 11 words in array 'y'.
    i= 0, x_i=10011011011101001, y_i=00000000000000000, z_i=01011010000, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=xxxxxxxxxxx, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=01011010000
    i= 1, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00110101001
    i= 2, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00011100000
    i= 3, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00001110001
    i= 4, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000111001
    i= 5, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000011100
    i= 6, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000001110
    i= 7, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000110
    i= 8, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000011
    i= 9, x_i=xxxxxxxxxxxxxxxxx, y_i=xxxxxxxxxxxxxxxxx, z_i=xxxxxxxxxxx, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000001
    i= 1, x_i=10011011011101001, y_i=10011011011101001, z_i=00000000000, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00110101001
    i= 1, x_i=10011011011101001, y_i=10011011011101001, z_i=00000000000, x_next=01001101101110101, y_next=11101001001011101, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=00110101001
    i= 2, x_i=01001101101110101, y_i=11101001001011101, z_i=11001010111, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00011100000
    i= 1, x_i=10011011011101001, y_i=10011011011101001, z_i=00000000000, x_next=01001101101110101, y_next=11101001001011101, z_next=00000000000, x_o=01001101101110101, y_o=11101001001011101, z_o=11001010111, d= 0, arctan[i]=00110101001
    i= 2, x_i=01001101101110101, y_i=11101001001011101, z_i=11001010111, x_next=10001000000001100, y_next=11010101110000000, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00011100000
    i= 3, x_i=10001000000001100, y_i=11010101110000000, z_i=11100110111, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00001110001
    i= 2, x_i=01001101101110101, y_i=11101001001011101, z_i=11001010111, x_next=10001000000001100, y_next=11010101110000000, z_next=00000000000, x_o=10001000000001100, y_o=11010101110000000, z_o=11100110111, d= 1, arctan[i]=00011100000
    i= 3, x_i=10001000000001100, y_i=11010101110000000, z_i=11100110111, x_next=10100010101111100, y_next=11000100101111111, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00001110001
    i= 4, x_i=10100010101111100, y_i=11000100101111111, z_i=11110101000, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000111001
    i= 3, x_i=10001000000001100, y_i=11010101110000000, z_i=11100110111, x_next=10100010101111100, y_next=11000100101111111, z_next=00000000000, x_o=10100010101111100, y_o=11000100101111111, z_o=11110101000, d= 1, arctan[i]=00001110001
    i= 4, x_i=10100010101111100, y_i=11000100101111111, z_i=11110101000, x_next=10101111000010011, y_next=10111010100101000, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00000111001
    i= 5, x_i=10101111000010011, y_i=10111010100101000, z_i=11111100001, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000011100
    i= 4, x_i=10100010101111100, y_i=11000100101111111, z_i=11110101000, x_next=10101111000010011, y_next=10111010100101000, z_next=00000000000, x_o=10101111000010011, y_o=10111010100101000, z_o=11111100001, d= 1, arctan[i]=00000111001
    i= 5, x_i=10101111000010011, y_i=10111010100101000, z_i=11111100001, x_next=10110100110111100, y_next=10110101000111000, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00000011100
    i= 6, x_i=10110100110111100, y_i=10110101000111000, z_i=11111111101, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000001110
    i= 5, x_i=10101111000010011, y_i=10111010100101000, z_i=11111100001, x_next=10110100110111100, y_next=10110101000111000, z_next=00000000000, x_o=10110100110111100, y_o=10110101000111000, z_o=11111111101, d= 1, arctan[i]=00000011100
    i= 6, x_i=10110100110111100, y_i=10110101000111000, z_i=11111111101, x_next=10110111101100100, y_next=10110010010010010, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 1, arctan[i]=00000001110
    i= 7, x_i=10110111101100100, y_i=10110010010010010, z_i=00000001011, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000110
    i= 6, x_i=10110100110111100, y_i=10110101000111000, z_i=11111111101, x_next=10110111101100100, y_next=10110010010010010, z_next=00000000000, x_o=10110111101100100, y_o=10110010010010010, z_o=00000001011, d= 1, arctan[i]=00000001110
    i= 7, x_i=10110111101100100, y_i=10110010010010010, z_i=00000001011, x_next=10110110010011011, y_next=10110011101110000, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= 0, arctan[i]=00000000110
    i= 8, x_i=10110110010011011, y_i=10110011101110000, z_i=00000000101, x_next=xxxxxxxxxxxxxxxxx, y_next=xxxxxxxxxxxxxxxxx, z_next=00000000000, x_o=xxxxxxxxxxxxxxxxx, y_o=xxxxxxxxxxxxxxxxx, z_o=xxxxxxxxxxx, d= x, arctan[i]=00000000011
    i= 7, x_i=10110111101100100, y_i=10110010010010010, z_i=00000001011, x_next=10110110010011011, y_next=10110011101110000, z_next=000000Finding VCD file...
    [2017-05-21 21:06:35 EDT] Opening EPWave...
    Done
    reg clk;
    reg [10:0] z0;
    wire [16:0] xn, yn;
    cordic_pipelined C1
    initial begin
    clk = 0;
    #120 $finish;
    end
    genvar j;
    generate
    for(j=0; j<C1.N; j=j+1)
    begin
    always @(*)
    begin
    $display("i=%2d, x_i=%b, y_i=%b, z_i=%b, x_next=%b, y_next=%b, z_next=%b, x_o=%b, y_o=%b, z_o=%b, d=%2d, arctan[i]=%b", C1.stage_generate[j].i, C1.stage_generate[j].stage_i.x_i, C1.stage_generate[j].stage_i.y_i, C1.stage_generate[j].stage_i.z_i, C1.stage_generate[j].stage_i.x_next, C1.stage_generate[j].stage_i.y_next, C1.stage_generate[0].stage_i.z_next, C1.stage_generate[j].stage_i.x_o, C1.stage_generate[j].stage_i.y_o, C1.stage_generate[j].stage_i.z_o, C1.stage_generate[j].stage_i.d, C1.stage_generate[j].stage_i.arctan);
    end
    end
    endgenerate
    endmodule[/syntax]
    input clk;
    input [10:0] z0;
    reg [(N-1):0] d;
    assign y[0] = 0;
    assign z[0] = z0;
    genvar i;
    generate
    begin: stage_generate
    .clk(clk),
    .arctan(arctan[i])
    end
    endgenerate
    genvar j;
    generate
    for(j=0; j<N; j=j+1)
    begin
    always @(*)
    begin
    xn = x[stage_generate[j].i]; // xn = cos(z0)
    yn = y[stage_generate[j].i]; // yn = sin(z0)
    end
    end
    endgenerate
    endmodule[/syntax]
    parameter i=0;
    input clk;
    input [10:0] z_i;
    output [10:0] z_o;
    reg d;
    begin
    x_o <= x_next;
    y_o <= y_next;
    z_o <= z_next;
    end
    always @(*)
    begin
    if(d == 0) begin
    end
    else begin
    end
    end
    endmodule[/syntax]
    •   Alt22nd May 2017, 02:21
      advertising
  20. #20
    ads-ee's Avatar
    Sep 2013
    USA
    6,440
    28,167
    40
    As you didnt post the design.sv file cant say why you are getting the problem with the always. You probably have an array name missing indicies in the always.
    If your problem is with the display of the output it is because you don't seem to understand how the for loop works. You are getting all 10 iteration of the display output anytime the inputs change. That is probably not what you intended. Personally I would put the display for loop inside a clocked always probably on the negedge.
    It might also be beneficial to add a display like a line of '-' or '=' before entering the for loop so you can tell where the separate times where it entered the for loop occur. You might also consider adding %t and $time to tell when in the simulation it entered the for loop.
