[SOLVED] Any Shortcut for assigning msb of a product to a variable
rahdirs
Advanced Member level 1
Mordor
I am multiplying two variables (16 bit) in verilog, so the maximum number of bits of the product is 32 bits. Is there any shortcut to assign the msb 16 bits to a variable ?
	parameter a = 16'hABCD;
	parameter b = 16'hFFFF;
	wire [15:0] c;
	assign c = a*b;
c will be assigned the 16 lsb bits, is there any shorter way of doing this without declaring a 32 bit variable as in,
        wire [31:0] product
	wire [15:0] c;
	assign product = a*b;
        assign c = product[31:16]
untested but the following might work:
Code Verilog - [expand]
assign c = (a*b) >> 16;
the >> will be performed prior to the assignment.
I can test this tomorrow when I'm sitting at my desk but you might be able to do this:
assign c = 16'(32'(a*b)[31:16]);
I am unsure why you need to avoid two extra lines to accomplish this? I don't know if the above will synthesize.
Are the input values "signed" or "unsigned"?
Klaus
In SystemVerilog, you can do select of a concatenation:
assign c = {a*b}[31:16];
