[SOLVED] Verilog Code giving wrong output for subtraction / -1 * number
rahdirs
Advanced Member level 1
Mordor
I am trying to do the following in Verilog: if count < 8, pass the i/p to o/p, else multiply the i/p by -j. Note: i/p is a complex number.
My code:
always @(count,out2_complex_bf1,out2_real_bf1) begin
if (count >= 4'b1000) begin
	out2_real_bf1_t 		<= out2_complex_bf1;
	out2_complex_bf1_t 	<= (~(out2_real_bf1)) + 1;
end else
	out2_real_bf1_t 		<= out2_real_bf1;
	out2_complex_bf1_t 	<= out2_complex_bf1;
end
I tried doing
by just putting -(out2_real_bf1). But o/p is all 0. I have attached the waveform.
Is the missing begin a typo? As written above you have the following code:
Code Verilog - [expand]
8
9
10
11
12
  end else
end
So the simulation is showing exactly what you wrote, assign out2_complex_bf1 to that ..._t version on every clock after the count goes over 8 as you replace the first assignment is overwritten.
BTW use the @* instead of writing out all the signals, less likely to make a mistake and end up with simulation synthesis mismatches.
8
9
10
11
12
  end else
end
I understood the error, there was a missing end .. statement. Not sure why it didn't raise an error
8
9
10
  end else begin
  end
end
It isn't an error, notice ads_ee's post that has the correct indentation.
