Pjdd
Advanced Member level 2
The OPA197 is a nice opamp. Many other opamps beat it in specific areas but the OPA197 has a well balanced set of all-round good specs. But, at ~US$2 apiece, it's a bit pricey to keep as a general stock part. I'm wondering if anyone here can suggest a lower-cost alternative. For those who are not familiar with the OPA197, here's a summary:
- 4.5-36V (or ±2.25 to ±18) power supply range with excellent specs down to the lower limit.
- 5.5nV/√Hz input noise
- 1mA supply current
- 0.25mV max offset, 25µV typ
- 5pA bias current
- Rail-to-rail input and output
- 10 MHz GBW
- 20V/µS slew rate
I'm willing to trade off some of the properties for a lower cost. First, this is what I want to retain:
- Wide power supply range, especially the low limit
- Low noise
- Low supply current
- R-R in/out
What I'm willing to trade off:
- Very low offset
- Very low bias current
- Bandwidth, slew rate and max supply voltage could be halved
I didn't list things like open-loop gain, CMRR, PSRR, etc because most opamps are good enough in these areas.
Can anyone please suggest a suitable opamp that's substantially cheaper than the OPA197?
- 5pA bias current
- 10 MHz GBW
- 20V/µS slew rate
- Low noise
- R-R in/out
- Very low offset
