Power tip needed.....external hole is 7mm diameter
T
treez
Hello,
We need a power tip so we can give 24V to our led strip light......we have the PSU, but the power tips shipped with the PSU dont fit the socket on the led product.
This is the kind of power tip needed (female).....
The external hole on the led product is 7mm in diameter, do you know what part number power tip is needed?
The pin inside the socket on the led product looks to only be sub 1mm in diameter.
Ask the supplier (I suspect you are already onto this though) as they should know, and be able to send you the correct parts.
A close up of the socket may help.
