Cousin
Newbie level 1
Help please, error is located where it is commented "[ERROR]"....I TRIED USING UNSIGNED, AND THE LIBRARIES ARE CORRECT. IM NOT SURE WHAT ELSE TO DO
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; library UNISIM; use UNISIM.VComponents.all; entity segmentdriver is Port ( display_A : in std_logic_vector(3 downto 0); display_B : in std_logic_vector(3 downto 0); display_C : in std_logic_vector(3 downto 0); display_D : in std_logic_vector(3 downto 0); segA : out std_logic; segB : out std_logic; segC : out std_logic; segD : out std_logic; segE : out std_logic; segF : out std_logic; segG : out std_logic; select_Display_A : out std_logic; select_Display_B : out std_logic; select_Display_C : out std_logic; select_Display_D : out std_logic; clk : in std_logic ); end segmentdriver; architecture Behavioral of segmentdriver is --component declaration COMPONENT segmentdecoder Port( Digit : in std_logic_vector(3 downto 0); segment_A : out std_logic; segment_B : out std_logic; segment_C : out std_logic; segment_D : out std_logic; segment_E : out std_logic; segment_F : out std_logic; segment_G : out std_logic ); end COMPONENT; COMPONENT clock_divider Port( clk : in std_logic; enable : in std_logic; reset : in std_logic; data_clk : out std_logic_vector(15 downto 0) ); end COMPONENT; Signal temp_data : std_logic_vector(3 downto 0); Signal clock_word : std_logic_vector(15 downto 0); Signal slow_clock : std_logic; begin -- component instantiation uut: segmentdecoder Port Map( Digit => temp_data, segment_A => segA, segment_B => segB, segment_C => segC, segment_D => segD, segment_E => segE, segment_F => segF, segment_G => segG ); uut1: clock_divider PORT Map( clk => clk, enable => '1', reset => '0', data_clk => clock_word ); slow_clock <= clock_word(15); Process (slow_clock) variable display_selection : std_logic_vector(1 downto 0); Begin if slow_clock'event and slow_clock = '1' then case display_selection is when "00" => temp_data <= display_A; select_Display_A <= '0'; select_Display_B <= '1'; select_Display_C <= '1'; select_Display_D <= '1'; display_selection := display_selection + '1'; -- 0 definitions of operator "+" match here [ERROR] when "01" => temp_data <= display_B; select_Display_A <= '1'; select_Display_B <= '0'; select_Display_C <= '1'; select_Display_D <= '1'; display_selection := display_selection + '1'; -- 0 definitions of operator "+" match here [ERROR] when "10" => temp_data <= display_C; select_Display_A <= '1'; select_Display_B <= '1'; select_Display_C <= '0'; select_Display_D <= '1'; display_selection := display_selection + '1'; -- 0 definitions of operator "+" match here [ERROR] when others => temp_data <= display_D; select_Display_A <= '1'; select_Display_B <= '1'; select_Display_C <= '1'; select_Display_D <= '0'; display_selection := display_selection + '1'; -- 0 definitions of operator "+" match here [ERROR] end case; end if; end process; end Behavioral;
