Problem in establishing GPRS connection to server
sunny_saha007
Newbie level 1
Basically am trying to establish the GPRS connection to send data to my server and also receive data to my server. Programming it through a Raspberry pi. While I was in India the Airtel connection would work and data being sent and received, as I moved to Australia, I tried the same with Airtel on roaming but gives me AT + CIIR *PDP : DEACT, what does this mean ?? All the data and roaming are on. Apart from that, I did try the connection with Vodafone on the sim900 but it gets connected but fails to send and receive data. Keeping the codes below , help would be appreciated.
def Gprs_Init_comm():
	ser.write("AT+CIPSHUT\r")
	sleep(2)
	ser.write("AT+CMGF=1\r")
	sleep(5)
	ser.write("AT+CIPMUX=0\r")
	sleep(5)
	ser.write("AT+CSTT=\"www.airtelgprs.com\",\"\",\"\"\r")
	sleep(7)
	ser.write("AT+CIICR\r")
	sleep(5)
	ser.write("AT+CIFSR\r")
	sleep(5)
	ser.write("AT+CIPSTART=\"TCP\",\"52.11.214.114\",\"85\"\r")
	sleep(8)
Subsequently changed the code to live.vodafone.com ... Gets connected but does not send data.
	sleep(2)
	sleep(5)
	sleep(5)
	sleep(7)
	sleep(5)
	sleep(5)
	sleep(8)
5/9/2017 16:18:34.592 [TX] - AT<CR>
5/9/2017 16:18:34.601 [RX] - AT<CR>
<CR><LF>
OK<CR><LF>
5/9/2017 16:18:47.040 [TX] - AT+SAPBR=3,1,"Contype","GPRS"<CR>
5/9/2017 16:18:47.078 [RX] - AT+SAPBR=3,1,"Contype","GPRS"<CR>
<CR><LF>
OK<CR><LF>
<CR><LF>
Call Ready<CR><LF>
5/9/2017 16:18:48.960 [TX] - AT+SAPBR=3,1,"APN","www"<CR>
5/9/2017 16:18:48.993 [RX] - AT+SAPBR=3,1,"APN","www"<CR>
<CR><LF>
OK<CR><LF>
<CR><LF>
SMS Ready<CR><LF>
5/9/2017 16:18:52.440 [TX] - AT+SAPBR =1,1<CR>
5/9/2017 16:18:52.461 [RX] - AT+SAPBR =1,1<CR>
<CR><LF>
OK<CR><LF>
5/9/2017 16:20:22.872 [TX] - AT+SAPBR=2,1<CR>
5/9/2017 16:20:22.892 [RX] - AT+SAPBR=2,1<CR>
<CR><LF>
+SAPBR: 1,1,"10.32.154.195"<CR><LF>
<CR><LF>
OK<CR><LF>
Change www to Airtel APN.
I posted Command alsong with Response.
Try it, Surely it will works for SIM800/900.
All the Best :)
