Negative array index
mahmood.n
Member level 5
What is the purpose of defining an array with negative index?! If I define
type myArray is (Natural <>) of bit;
Then I can use
signal myBitArray : myArray( 10 downto 0 )
and use myBitArray(10)...myBitArray(0)
But
type myArray is (Negative <>) of bit;
Means
signal myBitArray : myArray( -10 to 0 )
So what does myBitArray(-10) means?
its just a way of indexing. In VHDL you can use any type you want as the index, so if you wanted, you could to this:
type my_ar_t is array( character range <> ) of integer;
signal my_ar : my_ar_t('n' to 'y');
my_ar('r') <= 10;
You would need a purpose for a negative index. This currently is used for fixed point numbers in VHDL 2008. negative indicies represent fractions. x(-1) represents 0.5, x(-2) is 0.25, etc...
In other languages, negative values can be used to represent samples before a triggered event.
