elektr0
Full Member level 5
Hi guys,
we use an array of 20 linear voltage regulators (LDOs) with 5.5 Volts at the input. Each LDO has a 10uF SMD capacitor to ground in 0402 or 0602 size.
After assemby, the DC input resistance of the array, measured with standard ohm-meter, starts at 300kOhms and reaches 600kOhms or more after seconds (caps charging!).
The board did well for two days, now the DC input resistance of the array is 10 Ohms.
Any ideas? Could it be degradation of the capacitors?
Thanks you, best regards
-e
-e
