Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
  1. #21
    Junior Member level 1
    Points: 81, Level: 1
    Apr 2017
    15
    81
    Re: implementation of a band-pass filter
    Quote Originally Posted by CataM View Post
    The attenuation will be given by the filter's components. ADS will show what is the attenuation if you use the Filter Design guide...
    I am using that but ... I can't even set my filter order ...
    When I choose a low-pass filter I can set the filter order easily but for a band-pass filter, it doesn't work...
    so I have 2 problems now!
    1- I can't set filter order using Filter Design Guide (N=5, e-r,bans-pass)
    2- then attenuation
    If you give the known specifications for your filter, we can possibly clarify how far the remaining parameters are already determined by it. Or implement a design example.
    sure, an equal ripple band-pass with a center frequency of 3.5GH and FBW=20%...for 5dB, N=5
  2. #22
    Advanced Member level 2
    Points: 3,804, Level: 14
    Dec 2015
    Madrid, Spain
    690
    3,804
    14
    Quote Originally Posted by MAHYAR239 View Post
    2- then attenuation
    Filter's order gives the attenuation.
    Try with Maximally flat with following parameters:
    Ap=5 dB
    As= 122 dB
    Fs1=0.28 GHz
    Fp1=2.8 GHz
    Fp2=4.2 GHz
    Fs2=42 GHz
    That gives a 5th order Band Pass filter.
    •   Alt7th May 2017, 14:54
      advertising
  3. #23
    Apr 2017
    15
    81
    Ap=5 dB
    As= 122 dB
    Fs1=0.28 GHz
    Fp1=2.8 GHz
    Fp2=4.2 GHz
    Fs2=42 GHz
    but it's an equal-ripple one
    •   Alt13th May 2017, 10:14
      advertising
  4. #24
    Points: 228,909, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,481
    228,909
    100
    Do you want 5 dB pass band ripple?
Name:	Chebyshev 3.5 GHz 20% 5th 5dB.gif
  5. #25
    Apr 2017
    15
    81
    yes, that's what I want
    Now, I'm trying to design it using "Passive Circuit DG - Microstrip Circuits" feature of ADS...when click the "design "it shows the following warning ..how can I modify it?Click image for larger version.
    •   Alt13th May 2017, 13:11
      advertising
  6. #26
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,481
    228,909
    100
    5 dB ripple is quite high, that's true. It involves particularly a high Q of individual LC sections and respective sensitivity against parameter variations, also possibly extreme L and C values.
    I don't know if it's an exercise or a real hardware design problem.
  7. #27
    Apr 2017
    15
    81
    I wonder why my manual values of capacitors and inductors are not even close to the values ADS gives ...
    I got these using ADS:
ID:	138855 andClick image for larger version.
    but I have these values from manual calculations:
    for example : C1 = 0.1066 pF , L1= 19.3919 nH
    What's wrong?
  8. #28
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,481
    228,909
    100
    I got similar values as ADS with Nuhertz Filter Solutions. How did you calculate the filter? Same topology, same parameters?
  9. #29
    Dec 2015
    Madrid, Spain
    690
    3,804
    14
    It is very difficult to implement a 5th order band pass filter with only 1 pair of capacitor and inductor..
  10. #30
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,481
    228,909
    100
    I see C1 = 0.1066 pF , L1= 19.3919 nH if you design the filter for 0.5 dB pass band ripple.
    •   Alt19th May 2017, 18:16
      advertising
  11. #31
    Apr 2017
    15
    81
    I guess I had some mistakes in the manual calculation ...thanks all
