Current Mode Control of SCR Based Battery Charger
pradhan.rachit
Full Member level 3
Mumbai
Dear Experts,
I am working on a Fully Controlled Rectifier followed by an LC Filter for a battery charger application. The firing angle controller will be using an MCU and not any discrete analog circuits. The requirement is to operate the charger in two modes for lead acid battery charging.
Float mode - Used when the battery's SOC is higher than the setpoint. I'm using standard formulae to calculate the firing angle and apply the resultant voltage to maintain the charge of battery in this case.
Constant current mode - In this mode, the control variable will become current instead of voltage. I couldn't find any standard formulae to determine the firing angle for current control.
Could someone please highlight the options to implement current mode control in such a topology? I was thinking of using a P-I Controller for the same.
Awaiting your responses.
