How do I design a 2 input or 3 input NAND gates using a 4 input NAND gate (like 7420)
suman28pandit
Newbie level 2
I want to design a selectable input NAND gate using IC 7420 which should work as a 2- or 3-input NAND gate even when 2 or 3 inputs are applied
...or tie unused inputs to an appropriate logic level with a suitable value resistor.
If I understand you right, you want to let some pins occasionally be unconnected?
Just pull-up these pins. In case they are unconnected, they will have high level and the gate will act as 2- 3- input NAND (or NOT gate if you use 1- input).
A bit late, but still...
0 + 0 + 0 + 0 = 1
1 + 0 + 0 + 0 = 0
0 + 1 + 0 + 0 = 0
0 + 0 + 1 + 0 = 0
0 + 0 + 0 + 1 = 0
1 + 1 + 0 + 0 = 0
etc.
NAND is only all 0s make a 1, any 1s make a 0.
0 + 0 + 0 + 0 = 1
1 + 0 + 0 + 0 = 0
0 + 1 + 0 + 0 = 0
0 + 0 + 1 + 0 = 0
0 + 0 + 0 + 1 = 0
1 + 1 + 0 + 0 = 0
etc.
That is NOR, not NAND ;-)
NOR is 0 if any of the inputs is 1.
NAND is 0 if all of the inputs are 1.
Oh dear, you're right, just as well you pointed it out, thanks.
