You're welcomeThank you for your help Relayer.
The fuse rating is: 3.15A with time delay. You quoted the correct numbers at the bottom of yourThe problem is that I don't know the correct rating and delay time of the fuse.
I agree. I should have noticed it myself. :bang: It will be an 8 pin PWM Controller Integrated Circuit.Also to the right of the big condenser it seems something has been removed.
No. No point obtaining a fuse without replacing the missing IC. I doubt there will be anything wrong with any of theThe fuse is of the type T3 15A 250V, stamped on the pcb. I can try. Do you think it's worth changing the capacitors/condensers too?
I have to agree, you will need to find a schematic diagram of the PSU. Otherwise you'll be flying blind.That's why i wondering if anyone had the electrical diagram.
It seems the company don't want you to know the IC type, therefore don't want you to repair it. :drevil:Found photo online showing the 8 feet controller in question. Unable to know the type.
