Results 1 to 4 of 4
    Newbie level 1
    Points: 15, Level: 1
    Apr 2017
    15
    help with error message running code to recognise hand gestures
    I am new at this and a noob so speak to me like i am a 5 year old.
    Ok so i was making this project to recognise hand gesture controls using an accelerometer.
    I got this code off of the internet which i modified a bit but it keeps giving the same error message C129.
    I will post the screenshots along with the post for you guys
    please help
ID:	138097Click image for larger version.
ID:	138098Click image for larger version.
    •   Alt21st April 2017, 17:34
      advertising
    Points: 234,909, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    40,581
    234,909
    100
    Re: I need urgent help with a project
    You are including assembler code as C include files, that's not possible.
    •   Alt21st April 2017, 17:44
      advertising
    Banned
    Points: 5,417, Level: 17
    Jun 2016
    1,159
    5,417
    17
    You have to use inline assembly coding.
    •   Alt21st April 2017, 20:12
      advertising
    Member level 4
    Points: 1,080, Level: 7
    Altaero's Avatar
    Dec 2013
    St-Petersburg, Russia
    78
    1,080
    7
    Re: help with error message running code to recognise hand gestures
    Keil has a guide for inline asm:
    http://www.keil.com/support/man/docs...9124245889.htm
    As far as I know it also allows including pure asm files (.s) into the project and compile it along with c-files. But I've never done that.
    #include directive just places the content of selected file into it's position during preprocessing, so your compiler sees asm commands in you main.c file. That's why he shows errors.
    I'd recommend you to read about multi file projects. Putting source code into the header file (.h) is a bad practise, although C allows it. Putting pure ASM code to .h or .c file is meaningless and will lead to confuses.
