[General] help with error message running code to recognise hand gestures
Arkaprava1996
Newbie level 1
I am new at this and a noob so speak to me like i am a 5 year old.
Ok so i was making this project to recognise hand gesture controls using an accelerometer.
I got this code off of the internet which i modified a bit but it keeps giving the same error message C129.
I will post the screenshots along with the post for you guys
please help
Re: I need urgent help with a project
You are including assembler code as C include files, that's not possible.
You have to use inline assembly coding.
Keil has a guide for inline asm:
https://www.keil.com/support/man/docs/ARMCC/armcc_chr1359124245889.htm
As far as I know it also allows including pure asm files (.s) into the project and compile it along with c-files. But I've never done that.
#include directive just places the content of selected file into it's position during preprocessing, so your compiler sees asm commands in you main.c file. That's why he shows errors.
I'd recommend you to read about multi file projects. Putting source code into the header file (.h) is a bad practise, although C allows it. Putting pure ASM code to .h or .c file is meaningless and will lead to confuses.
