Results 1 to 7 of 7
    Newbie level 3
    Points: 26, Level: 1
    Apr 2017
    26
    Ltc3105 does not boost convert the input
Name:	ltc3105 SCHEMATIC.PNG
    In my design, I give .250V to 1V as input but I do not get any output. And there is no boost conversion of the input. Help me out in this issue.
    •   Alt21st April 2017, 16:41
      advertising
    Points: 227,483, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,208
    227,483
    100
    Re: Ltc3105 does not boost convert the input
    Looks right at first sight, although I'm not sure if the device can achieve nominal output voltage with 1V input and the load resistors. Do you observe any activities at AUX and SW pins?
    Newbie level 3
    Apr 2017
    26
    According to the data sheet the circuit is correct. I have also simulated in LT spice and saw. I get correct output , but in board I do not get output. At AUX I do not get the required output as required in data sheet. The voltage across inductor is same as input.
    •   Alt21st April 2017, 21:04
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,208
    227,483
    100
    Exact voltage?
    Points: 41,798, Level: 49
    Most Frequent Poster
    Apr 2014
    8,549
    41,798
    49
    To verify the circiut you could just measure the voltage on every single pin and post it here.
    Newbie level 3
    Apr 2017
    26
    Exact voltage?
    The voltage that I do get at AUX pin is 200mV.
    •   Alt22nd April 2017, 11:13
      advertising
  7. #7
    Newbie level 3
    Apr 2017
    26
    The voltage that I get at all the pins are as follows:
    1. At the AUX pin I get 200mV.
    2. At the MPPC pin I get 50mV.
    3. At the LDO pin I get 100mV.
    4. At the Inductor (SW pin) I get the same input voltage which I gave.
    5. At the Vout Pin I get 250mV if I give 1V as input.
