doncarlosalbatros
Full Member level 2
I need to make a voltage controlled current source for nichrome wire. It seems like I need a circuit which translate 0...5V range voltage input to a 0...8A current. I mean a voltage controlled current source. I can use a DC power supply which can supply this current.
Is there a topology or any suggestion circuit for example composed of an opamp and a power transistor? Or any specific IC would work as well.
I would be glad if one can share a circuit diagram or components for this purpose.
Regards,
Regards,
