Results 1 to 2 of 2
    Full Member level 5
    Points: 3,224, Level: 13
    Sep 2008
    315
    3,224
    13
    Placement of the shielding material to the wireless power systems
    Hi All, I have a 13.56MHZ wireless power transfer system. In this system, there is also the data link operating at the other frequency.
    I was trying to use the flexible shielding material to minimize the noise coupling from the power coil to data coil. However, if I use the material to cover the power Rx coil, it will block the power transfer from Power Tx coil, and there is no power supply of the board.
    I am using the co-plane structure for the Rx coils. The picture is shown here.
    The flexible shielding material (for 13.56MHz shield) comes from here http://katalog.we-online.de/en/pbs/WE-FSFS . Would anyone teach me where should I place the material? Thank you very much!
    •   Alt20th April 2017, 16:13
      advertising
    Member level 5
    Points: 1,191, Level: 7
    Jul 2014
    UCSD
    92
    1,191
    7
    Re: Placement of the shielding material to the wireless power systems
    you want to set it up something like this I believe
    Also make sure you tune your system with the shielding in the way, it will alter your coil L and Q.
