+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 3
    Points: 1,009, Level: 7
    Join Date
    May 2013
    Posts
    65
    Points
    1,009
    Level
    7
    Capturing 10G bit without any loss using SFP plus port in windows
    I am using hpe 560 SFP plus adapter from intel in one side. I have an ultra scale FPGA from kintex family in the other side. I create 8K jumbo Ethernet packets in FPGA. i used winpacp and visual studio in windows. i have packet loss. Is there any idea how to capture this data rate in windows?
    •   Alt20th April 2017, 16:12
      advertising
  2. #2
    Full Member level 4
    Points: 2,774, Level: 12
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    United States
    Posts
    237
    Points
    2,774
    Level
    12
    Re: Capturing 10G bit without any loss using SFP plus port in windows
    If your FPGA is transmitting jumbo packets as quickly as possibly, it is very likely you will have packet loss. I haven't used winpacp but have had pretty good results with Wireshark for capture and analysis.
    I admit to not trying to run at 10G, only 1G, and not such large jumbo packets. I no longer have that PCB (project with another company).
    •   Alt20th April 2017, 18:45
      advertising
  3. #3
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    I kind of doubt you'll find a PC that is cable of handling 10G Ethernet jumbo packets regardless of the software running on the machine. 1G yes, but 10G is an order of magnitude more data.
